Your favorite home theater in a box?
exalted512
I get asked a lot...'what is your recommendations for a home theater system?'
But 95% of the time, they're always referring to the whole home theater in a box system and are looking to spend $500-1000 depending on the person.
I know you guys all know the type. What are your guys recommendations when it comes to the people where the most work they want to do is buy a single surround sound set of speakers and a separate receiver that will do 5.1?
-Cody
-Cody
Post edited by exalted512 on
Why waste more than a couple hundred bucks if you don't care about the sound?
If I was forced at gunpoint to toss a name out there, I would go with a Denon Box....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I personally haven't heard a ton, but for all in one packages I would say onkyo seems head and shoulders above the rest. Good separate receivers that can be kept if you upgrade, powered (though not particularly good) subwoofers, and halfway decent speakers that at least have separate midwoofers and tweeters. I think the speakers are the weak link, and they tend to be on the large side, but for overall quality I think onkyo is hard to beat.
Peace,
PaulLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Onkyo makes great HTIBs.
Polk surrondbar 50 they sound really good. I might get one for the bed room.Sony KDSR70XBR2 70" RPTV
POLK LSi-25s (Front)
POLK LSi-FX (Surround)
POLK LSi-C (Center)
POLK LSi9s (Rear)
Dual JL Fathom F113 :eek: (Sub)
Onkyo TX-NR5007 (Receiver)
Oppo BDP-83 (Universal Player)
Toshiba HD-XA2 (HD-DVD/DVD)
XBOX 360 Elite -
nooshinjohn wrote: »Why waste more than a couple hundred bucks if you don't care about the sound?
Because some people do care about the sound enough to want to upgrade from the terrible speakers on their tv to something better, but not everyone cares enough to join an audio forum and talk about it and spend thousands of dollars.
Thanks for the suggestions guys, keep em coming.
I want to get one for our bedroom. Unfortunately, our tv is really small and I dont want the thing to make it look any smaller!
Bose
Just speakers - Hsu Ventriloquist system.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
I often see HTIB packages which consist of seperate receiver and speakers (IE: Yamaha receiver with Polk RM10 package). Those are usualy previous years series that are combined to offer a package at good value (500$). The advantage of such package is that they are actually separate and therefore upgradable. As previously suggested, a SB is also a valid option for a bedroom or any small room however, you must add a receiver and your cost would bring you closer to a 1K spending.DARE TO SOAR:
A family member and a friend were asking me this just the other day.. After looking around a little with them; they got the Polk RM705 system for cheap from Newegg.. I gave my mom my old Onkyo receiver and the friend bought an lowered end Onkyo to power the system.. ended up costing about $600 total i think for RM705 and Onkyo.
Both parties are very happy.. I don't care much for the systems however
Jason2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
Onkyo HT-S9100THX if the room is small to medium sized.
Definitive Technology Procinema 600 and just buy an entry level receiver. That will be right at the $1000 mark retail, but should sound a lot better than any of the HTIB's.Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI -
Buddy of mine bought his dad an Onkyo HT-S7200 for Xmas.
I have only heard this in the store and it would sound OK in a small room. It also has TrueHD, DD Plus, DTS-HD Master Audio, Neo6 & PLIIz Decoding. He checked with me before he bought it. For what it is, It's a decent system.
It was perfect for his Dad as he had just bought a new HD TV and his brother was getting him a BluRay player. Via ICQ, he just answered that his dad was really happy with the system. He has never had a surround system before, so perhaps his expectations were lower than what others might be.
The HT-S6200 is virtually the same thing but doesn't have the tower mains.
The HT-S9100 is THX certified, offers TrueHD, DTS HD Master, PLIIx, Neo 6
ScottWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
Because there can be a tremendous difference in quality between a $200 HTIB and a $1000 HTIB.
I'll never buy another HTIB, but there are plenty of people that will. Not everyone cares enough, or can afford, to research and build an entire component HT setup. Some people want the simplicity of purchasing the whole setup at once, but still want to get the best sound that they can.
Believe it or not, there are some little HTIB setups out there that sound DAMN good. They aren't going to equal a well thought out component system, but they make for a very dramatic improvement over TV speakers.
If I were to get a HTIB setup...I'd probably go with Onkyo, for the same reasons others have mentioned above.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
+1 on the Onkyo....the closer to their highest model the better. But also as said...HTIB are not what most of us would want in our AV rooms.
Onkyo makes some pretty nice HTIBs. I had one before my rather large, recent upgrade and in a small to medium sized room it sounded pretty darn good.Samsung LN52A650 : PS3 : RTi A7s : CSi5 : SVS PC12-NSD : Pioneer VSX-9040THX : Emotiva XPA-3 =
Sonys the king of htib because most companys out there cant offer the value that sony can .......theyr the kings of cheapy cheap
SolidSqual wrote: »Onkyo makes great HTIBs.
+1. Buddy of mine got one a few years back and I have to say...not too bad for less than $500.Things work out best for those who make the best of the way things work out.-John Wooden -
How about Polk's offerings?
http://www.polkaudio.com/homeaudio/surroundbar/index.php?s=surroundbar-sda-instant-home-theater
Personally, I would go that route to start a system before I would buy ANY htib. If, like the original OP, you are looking to spend between 500 and 1,000, then Polk has some answers for you. -
I just gave my onkyo away which I had for about three years.Most people who really didn't know or care much Thought it sounded great.For 599 It was really a nice system.Parasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC -
I would add my vote for some of the Onkyo systems - they generally make good stuff at a decent price.
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Rtia9 /csia6 / FXi A6
Samsung LN46A650
SVS PB-12-NSD sub
Audio Research SP-9 MKIII (GNSC mods)
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Audio Aero Prima CD player
Pro-Ject debut -
I had an Onkyo HTIB before I put together my current system, and it sounded pretty damn good. I paid $450 for it at CC and they threw in two stands for my front channels. It was a 7.1 system and it had 1000W of total power. I sold it to a buddy of mine for $250 about a year and a half ago, and he is still very happy with it. My wife is always telling me that we should have kept it and put it in our bedroom or downstairs, she liked it very much too.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
I want one just for the hell of it..LOL;) -
i haven't sold an HTIB in months, i just point out the value of a component system and people either have the money or dont.setup
Panasonic 46pz85
Polk RTi A9's
Polk CSi A6
FXi A6's
Energy s12.3 sub
Denon 3808ci
Pioneer elite dv-79
Monster 1850
Denon dp500m w/ grado green
PS3,XBOX 360, NES -
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
