Voight pipes
rs159
rs159 Posts: 1,027
edited November 2003 in Speakers
Anybody have any listening experience with them? What's the general consensus? Just curious...
http://kosat.consultit.no/~ketil/lowther/voigtpip.html
Post edited by rs159 on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    It depends on what driver you use in it.
    Lowther ($$$$), Fostex ($$), Pioneer/Ratshack ($)....
    Check the partsexpress project showcase, they feature a 2-way model.
  • rs159
    rs159 Posts: 1,027
    Russ, seems like you fancy the cheapy Pioneer 8" in a VP, eh? From what I've read it isn't terrible but then I didn't look very hard
    Not to say Lowther isn't nice; but, you know - $$$$
    edit - seen the PE project before - crossover, blech! These things are supposed to be cheap and simple! :lol:
  • gidrah
    gidrah Posts: 3,049
    I was going to build a pair before I made my periscopes. I'll still build them someday though.
    I've heard a few pair. They all sounded good. Some even sounded great.
    http://cain-cain.hypermart.net/audio/abby/index.html
    These sound great. A few hundred bucks for wood and Fostex drivers and you're golden. If you want to experiment with less expensive drivers first, I wouldn't blame you. Check your local Radio Shacks and see if they have any full range speakers left.
    Good luck.
    Make it Funky! :)
  • gidrah
    gidrah Posts: 3,049
    More reading material.
    http://www.melhuish.org/audio/enclosuretqwt.htm
    Check out Martin King's stuff. Very thorough site.
    Make it Funky! :)
