Good AV receiver match for RTA 15TL
turbocat
turbocat Posts: 4
edited October 2004 in Speakers
Hello,
I'm glad I found this forum, until recently I haven't looked at stereo equipment for 12 years, so I'm a little out of the loop and was hoping you guys could give me some advice. I've had these speakers since '91 and they've served me very well. My problem now is that I'm looking for an up to date AV receiver so I can do 6.1 surround. Before this they've always been hooked up to a Carver TFM 25 amp. The amp has been great too, but has recently developed some sort of distortion in the left channel. At some point I will look into getting the Carver repaired so I can use it again for 2 channel music listening. But for now, I'd like to get a home theater started and was wondering how much power I should be looking for in a receiver to run these sizable speakers. So far, I've looked at Denon, Yamaha, and Harmon Kardon. Also, my budget for the reveiver is no more than $700. Most of the units I've seen are rated between 65 watts per channel and 110. I'm not sure if this will be sufficient to drive the RTA 15's safely. So any advice on power and brands would be greatly appreciated!! Thanks much.
:D
d white
denver co USA
Post edited by turbocat on
  • setzer808
    setzer808 Posts: 173
    edited November 2003
    Glad to hear you've suffered a bit from the HT bug. We are here to help.
    Regardless of what reciever you purchase, getting the carver repaired and using it as an amp (through pre-outs on the reciever) would be an option if you really love the pairing of these two.
    I'd say that any reciever within your target price range (up to $700) that bears the Denon, Yamaha, NAD, Pionner Elite, H/K, Onkyo name (and many others I didn't name) would cover your needs quite well. No matter what anyone here says (including me), I'd say your truest answer will be going and listening/demoing some models in your price range. Happy hunting.
    Polk CS245i Center
    Polk RT55i Mains
    Polk RT25i Rears
    Polk PSW-350 Sub -in storage.
    Yamaha RX-V681 A/V Reciever
    Sony SCD-CE595 SACD Player
    F1nut Posts: 51,760
    Hey TC,
    You'll never find a receiver good enough to power the 15TL's and they really suck at HT, but seeing as I'm such a nice guy I'll take them off your hands for a couple of hundred. It should be enough to get you started with one of those HTIB set ups.
  • bigsexy1
    bigsexy1 Posts: 557
    You can get a Denon 3803 for well less than $700 from 6th Ave, an authorized dealer with full warranty. I've read somewhere that it puts out something like 138 watts per channel in 2 channel stereo mode.
  • turbocat
    turbocat Posts: 4
    Hey guys,
    Thanks for your responses. Bigsexy, thanks for the heads up on that sweet deal from 6 Ave.com. $648.00 + free shipping for the 3803 sounds like a deal to jump on!!!:)
    TC
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited February 2004
    Sorry to jump in on this one, just 1 quick Q.
    Quote from F1nut
    >the 15TL's and they really suck at HT<
    are you serious ? I was thinking of these speakers to replace my RT-800i for better 2 channel, if it didn't kill my HT end of it and would match somewhat my current setup.
    Fronts RT-800i
    Center CS-400i
    Rears RT-600i
    Sub Paradigm servo-15
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • hoosier21
    hoosier21 Posts: 4,418
    rest assured F1nut was kidding
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    F1nut Posts: 51,760
    Hehe :D
  • I-SIG
    I-SIG Posts: 2,243
    <SNORT!>
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • warlocks1
    warlocks1 Posts: 1,283
    Turbocat, I am using a set of RTA15's for my mains and my rears. I good quality receiver will work, but to make the 15's sound the way you are used to, you will need a seperate amp. I am using Carver's and love them. Get the Carver fixed.
  • Tour2ma
    Tour2ma Posts: 10,177
    I'd look into the used market at least as a comparison.
    The 25's don't demand that much $$$ used and Carver's bench fee is ~$150. So unless you have a local repair that is reasonable and Carver familiar, it may be worth buying a replacement.
    More later,
    Tour...
    Vox Copuli
  • 00p225
    00p225 Posts: 100
    I recently picked up a pair of SDA-1C's from a member of this forum. These are very power hungry rated from 50-500 watts per channel and only 90dbs efficiency. I tried them with my Mcintosh MC2100 which is rated at 100wpc but actually runs closer to 150. I thought I'd try it on my HK AVR 500 just for the heck of it and it runs them nearly as well as my mac. This particular receiver is rated at 80wpc from 20-20K into 8ohms. Not quite the sound quality of course, but I was really suprised to say the least. In 2 channel mode, I can pull better than 100dbs cleanly with no distortion. The other thing is these are 6 ohms impedance and dip to 2 ohms at some frequency's and the HK doesn't get hot or kick into protection (never has with any of my speakers) mode even when run hard for a half hour at a time I'm not pushing HK here but just posting my findings as I'm sure there are plenty of other options out there. I will say however, since I have'nt heard the 15Tl's, if they are a warm sounding speaker, they probabally won't do well with the HK's as they are rather layed back and can sound dark when matched with polite speakers. In this case the Denon's or Yamaha's would be the better choice.
    Main System
    Pre - Homebrew 12au7 tube preamp
    Amp - Eico HF-87 with EHEL34's
    Source - Modded Toshiba 3950
    Interconnects - DIY Belden
    Speakers - Polk SDA-1C
    Basement System
    Pre - McIntosh C-28
    Amp - McIntosh MC2100
    Source - Modded Toshiba 3960
    Tape - Pioneer RT-707
    Turntable - Thorens TD150MKII with Denon DL-160
    Speakers - Pioneer HPM-100
  • warlocks1
    I haven't listened to the SDA1's but they do use similar drivers, so imagine the sound is similar. I have never listened to my 15's with a receiver. I have used Adcom and Carver amps. I can't really say I heard a difference, but I think I like the Carver more. I had a Harman Kardon AVR5? Prologic receiver driving my old 11t's easily. I was very satisfied with the pairing.
  • turbocat
    turbocat Posts: 4
    edited September 2004
    Hey guys,
    Haven't been around in a looong time, but just thought I would give an update since I started this thread and these speakers seem to have somewhat of a following. Well, I got the Denon 3803 and have been more than happy with it. A great start for HT. Very pleased with how it matches with the 15's musically as well.
    I decided to hold on to the old carver, and get it fixed someday down the road. It really made the 15's thump:D
    ...warlocks, wow, those are some pretty serious rear speakers. Nice setup.
    ....F1 I just saw the refurb you did on those 15's, nice work:cool:
    thanks again guys
    F1nut Posts: 51,760
    Thanks TC, glad you liked them...I sold them, so my offer still stands to buy yours for a couple of hundred. ;)
    Seriously, glad you're enjoying yours!
  • dharding
    dharding Posts: 61
  • turbocat
    turbocat Posts: 4
    I appreciate the offer, but they're stayin put, man:p
    Hey Dan, That's what I was planning to do with my old Carver amp. So in that configuration, I assume it's easy to switch between the external amp for 2 channel music listening, and the 3803 amps for theater. Correct?
  • dharding
    dharding Posts: 61
    edited October 2004
