DSD+Dolby PLIIx not working
lumpy
lumpy Posts: 113
edited March 2010 in Electronics
I listen to SACD with an oppo 980 connected to a Yammah 863 via an HDMI cable. I have been able to select Dolby PLIIx as additional surrond processing to get the subwoofers into the two channel mixes. I recently rearranged the room and when I reconnected everything - I can no longer get this to work.
Is this an HDMI version issue? or could there be another problem? I have tried a few different HDIMI cables with the same results.
thanks,
pop
media room: Lsi25 mains driven by an audiosource amp300, LSi9's driven by another amp300, LsiC drivin by an audiosourcAmp200, Lsi7 rear channels driven by receiver - Yamaha 863, Panamax 5300, epson 6100 w/ 106" elite cinatension2 screen, HPz555 media center, oppo 980, techniques SLbd3 turntable,xbox and ps3,
living room: VM30 mains driven by a niles 2125, VM20 center and VM10 surrounds, velodyne dsp10, yamaha rxv661, cambridge audio dvd89, panamax5300, philips 42" plasma
Post edited by lumpy on
  • cstmar01
    cstmar01 Posts: 4,424
    edited March 2010
    check your settings and make sure nothing from the rearrangement didn't change. its sounding like something got reset and that you would have to correct it.
  • lumpy
    lumpy Posts: 113
    edited March 2010
    not a set up issue - I did double check though. the only thing that is different is that the surrounds are now run off a sepperate amp. they were run off the receiver previously.
    pop
