AVR/Preamp ?'s
curved
curved Posts: 664
edited March 2010 in 2 Channel Audio
Now that I just purchased my preamp (Nakamichi CA-5), I would like to incorporate that in with my main system. I need recommendations on the following:
1. Use a Splitter directly into the amp (http://www.parts-express.com/pe/showdetl.cfm?Partnumber=091-515)
2. Use the tape loop in the Nakamichi in/out to the amp.
3. Suggestions?
I'm really excited to see how this preamp sounds!! Thanks for the input!!
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
Post edited by curved on
  • TG Meat
    TG Meat Posts: 159
    edited March 2010
    Hey, I don't know about the tape loop. In my Parasound P7, the tape loop bypasses the pre-amp, just in and out.
    Anthem D2v
    NAD M50 Music Server
    B & K Reference 200.5
    Parasound A21
    B & W 804 (Mains)
    B & W HTM1 (Center)
    Polk Rti4 (Surrounds)
    PS3
    Seaton Submersive HP
    Pioneer PDP 6010FD Kuro
    heiney9 Posts: 25,425
    edited March 2010
    Great preamp, I owned one for damn near 20 years. Not sure about the ways you want to incorporate it. The tape loop probably isn;t a great idea if you're looking for maximum fidelity. I used mine in a strictly 2 channel rig in the conventional way. Not sure you can get maximum sonic benefit using it cobbled together in an HT rig.
    Anyway you can just hook it up to one amp, one source and one pair of speakers rather than trying to cobble it into your HT rig?
    tonyb Posts: 33,069
    edited March 2010
    Agree with Heiney, your going to lose the very benefit of having a pre by cobbling it with a receiver that may or may not pass thrue the signal untouched.
