I want to mount my Tsi200...
zorrier
zorrier Posts: 31
edited January 2011 in Speakers
I want to mount my Tsi200 on the wall because they will be my surround sound (L and R) any suggestion? Good price?.
Quisiera montar mis Tsi200 en la muralla porque estos ser
Post edited by zorrier on
  • Zeros
    Zeros Posts: 940
    edited March 2010
    Here you go, monitor 40's wall mounted. They are the same size as your Tsi200's. Scroll down to see instructions, the brackets used and pictures:
    http://www.polkaudio.com/forums/showthread.php?t=93943&highlight=wall+monitor+btech
    He used PinPoint AM40 brackets
  • zorrier
    zorrier Posts: 31
    edited March 2010
    Do you think those will work?
    Pinpoint AM10 Tilt/swivel wall-mount speaker brackets
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited March 2010
    +1 on Zeros post, that is a very good thread for wall mounting the Monitor 40's and as he said the TSi 200's would be the same to install.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • zorrier
    zorrier Posts: 31
    edited March 2010
    I know, I just was wondering about the other ones. Pinpoint AM10 Tilt/swivel wall-mount speaker brackets. Are cheaper and support the weight.
  • wutadumsn23
    edited March 2010
    Not sure to be honest, I would imagine if they will support the weight, they should work. I was just referencing that thread because it was the only one I knew of and that was the mount he used.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • zorrier
    zorrier Posts: 31
    edited March 2010
  • wutadumsn23
    edited March 2010
    Only issue I can see would be that with the 10's you will have to drill holes in the 200's to secure them to the bracket. With the 40's they just sit on the tray. Drilling holes in speakers can sometimes be a bad idea, that and I would imagine it would be a less secure mount than with the 40's. The weight of the 200's would be on the tray of the 40's, whereas the weight of the 200's would be on the screws with the 10's.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • zorrier
    zorrier Posts: 31
    edited March 2010
  • Ruiner13
    Ruiner13 Posts: 16
    edited January 2011
    -Jeff
    Jeff, your all over the place here man, rock on. I'm scared as hell to drill into the tsi200's.
    1/2 an inch holes don't break through the casing of the speaker?
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2011
    The B-Tech BT77 is the bracket you guys need.
    EndersShadow Posts: 17,716
    edited January 2011
    dorokusai wrote: »
    +1. Its also known as the AM40 Pinpoint mount I believe.
  • Monster Jam
    Monster Jam Posts: 919
    edited January 2011
    I wonder if zorrier has mounted his speakers yet? OP was in mid-March.
    TSi speakers are fine speakers, but I'm not sure I'd mount them.
    "Thems pretty grills ya got der."
    Do you hear that buzzing noise? :confused:
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2011
    dorokusai wrote: »
    +100000000
    I've got a pair of B-tech BT77 wall mounts, and they're excellent. I'm not currently using them, since I don't have any bookshelf speakers to wall mount at the moment...but they worked very well with the RTi6's that I used to have. I'm sure I'll put them to use again someday.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
