New to this
KrockP10KrockP10 Posts: 4
edited March 2010 in Car Subwoofer Talk
Im very new to this car audio thing... So could someone tell the difference between 4ohms, 2ohms, and 1ohms
Post edited by KrockP10 on
  • DSkipDSkip Posts: 16,120
    edited March 2010
    When the ohms get smaller, the amp runs hotter. Some amps can't handle 1 ohm and if you try to run them 1 ohm, you will most likely destroy the amp. Its the same in home audio, you just don't see it as often. The speakers determine the impedance the amp runs, and for more on that you can scope out Crutchfield. Lots of good info there in their help section.
Howdy, Stranger!
