Timber match question
I recently ordered some RTIa7's and could not afford a matching A6 center. However, I found a sweet deal on a new CSI5 ($160) and jumped on it. Will these two play nice together? I know the A6 is the updated version of the CSI5 but will I actually notice a difference? Coming from my current onkyo htib, everything will probably sound amazing regardless, but I was just curious. Anyone else use a similar setup to mine?
Samsung LN52A650 : PS3 : RTi A7s : CSi5 : SVS PC12-NSD : Pioneer VSX-9040THX : Emotiva XPA-3 =
Post edited by Agent on
The CSi5 should match just fine.
I would call Polk CS and check. Timber matching the front stage is a very nice thing to do.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
The csi5 is gona be sonicly identical you should have no worries there
It will match dont worry about it.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110
