Need help with TV stand that will fit a Polk CS2
Northman11
Northman11 Posts: 2
I am slowly building up my home theater room and recently purchased a Polk CS2 to go along with my Monitor 70s and 30s. Now I just need to find a tv stand that will fit the CS2 inside of it. I will wall mount a 65" plasma tv over the tv stand so I'm not looking at anything too tall. It needs to have enough room for my AVR, cable box, Xbox, and a blu-ray player.
So far my search fu hasn't helped in my quest for a tv stand. Any ideas would be greatly appreciated.
Post edited by Northman11 on
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited March 2010
    First off, welcome to Club Polk. That CS2 is a beast, and can be hard to accommodate, but you will be glad you got it. I don't know of any specific models off hand, but any 3 shelf system should work. Easy for me to say because I don't know your taste, but I would check out Walmart, Target, even Best Buy. Good luck.
    -Jeff
    http://www.walmart.com/browse/Furniture/Home-Entertainment/Audio-Media-Towers/_/N-8tsmZaq90Zaqce/Ne-2p4i?catNavId=+635499&ref=125874.411862&ic=48_48&tab_value=172608_All There are a few nice ones in here, take a look.
    http://www.target.com/Flat-Panel-TV-Stands-Entertainment/b/ref=sc_iw_r_2_0/180-8976595-1642637?node=277271011 Here also
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • kcoc321
    kcoc321 Posts: 1,788
    edited March 2010
    ..... That CS2 is a beast......
    So IF the CS2 is a beast at 7-3/4" H x 21-1/4" W x 11-1/8" D & 17lb then what is a CSi5 at 7-11/16" H x 24" W x 14-1/2" D & 29lbs ???
    Sorry, just had to ask....:D
    As far as a stand, it really depends on your style and budget....
    wood or granite?? Modern or traditional?
    If clean, modern and high SQ is your style, I love the look of these:
    376_118_big.jpg?rand=806223400
    (SolidSqual's showcase)
    VTI gear here:
    http://www.racksandstands.com/VTI-BL404-VI1001.html
    Or more traditional style
    http://www.audioadvisor.com/prodinfo.asp?number=SMKSL20&variation=CHEBLK
  • wutadumsn23
    edited March 2010
    LOL, I know the CS2 is by no means the biggest, baddest center in the Polk lineup, and probably pales in comaparison to many. Was just comparing it to the CS1, lol.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
    edited March 2010
    WELCOME TO CLUB POLK!!
    How much are you willing to spend because I know of a unit that will house that? Don't recall the model at this point. Two friends have a cabinet that can house a CS2 perfectly and lots of other gear as well. I'm pretty sure it runs over 400 dollars though. A nice piece of furniture.
    I'll see if I can download a pic? And find the model later!
    cnh
  • superjunior
    superjunior Posts: 1,632
    edited March 2010
    this stand from best buy works well for me. its built like a tank, holds a ton of gear and plenty of room for a center. the post is removable and the tv mount also doubles as a wall mount for any size flat screen.
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • Northman11
    Northman11 Posts: 2
    edited March 2010
    I should have mentioned this in the original post. I'd like to find something that allowed the components to be inside the cabinetry. I have two little children and the less that they see, the less that they are tempted to mess with Plus, it allows me to keep the wiring all neat and tidy. I will definitely take a look at the link you guys posted.
    cnh - I'd definitely be interested in a pic.
  • JimKellyfan
    JimKellyfan Posts: 696
    edited March 2010
    I have from Sears a 32" Sony TV, and I bought with it, a ( TechCraft FS3212 - silver stand that had glass doors { still have 'em, but took off for my CS2 } works fine.
    Onkyo TX-NR636
    Main - polkaudio Monitor 60's
    Center - polkaudio CSI A6
    Sub - polkaudio PSW10
    Sub2 - polkaudio PSW505
    Surrounds - polkaudio Monitor 40 series II
    Front Height - polkaudio Monitor 40's
    Audio Outdoors
    Pioneer VSX 406 - polkaudio Atrium 5
    Shed
    Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
    Shed 2
    Nakamichi soundbar
