Bi Wiring Rears ????????
Murray1
I have my L,R,C bi-wired with Canare S411. Just ordered a new set of RTiA3's and need to order cable. Should I stick with Canare and bi-wire rears or do I have options (i.e. bi-wire L,R,C but do not bi-wire rears). Thanks for your input.
Post edited by Murray1 on
I wouldn't,waste of money. Stick with a single wire run and buy the best you can afford.HT SYSTEM-
lsi 9's -
Is it ok to biwire front soundstage and not biwire the rears??????
Sure, but you will gain absolutely nothing from doing so. Your AVR only has one power source for the speakers and it is split up amongst those channels. It isn't going to send twice as much power to a speaker from an unused set of speaker terminals on the back of your AVR by simply adding a second set of wires to them. There are many posts her on this forum about this topic, and most will agree that there is no benifit from it. If you want to add some real powwer to your speakers and your AVR has pre outs, add an external amp. Then you will hear what your speakers are really capabe of.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
