BMW 7 series audio install
2
  • audiobliss
    audiobliss Posts: 12,518
    edited March 2010
    Honestly this is my first time doing fiberglass after talking about it over a year. I think just reading reading and asking questions helped me a lot.
    Would not mind helping you out with your install. After all last year I was flown to california for an install.
    Hahaha, flying out to California for an install...that's pretty awesome.
    It'll be a good while before I have anything I deem worthy of putting fiberglass in. I just look forward to trying it out one day.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited March 2010
    Added the second layer and will let it set good over night than sand and bondo tomorrow and paint.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • bigaudiofanatic
    edited March 2010
    Just went down and put a layer of mat and resin over what I just did.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited March 2010
    Laid matt down.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • exalted512
    exalted512 Posts: 10,734
    edited March 2010
    Looks great! A tip for doing kick panels though. I tend to not use fleece as its too thick and can look bulky when put back in the car. Not the shape itself, but where it lines up with the other panels. Can also cause fitting issues as well. Instead, I use grill cloth type material. Very thin, more flexible than fleece to get out all those pesky waves...and it goes on 100x smoother once you have the resin on it.
    Keep up the good work!
    -Cody
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited March 2010
    Looking good.:)
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • bigaudiofanatic
    edited March 2010
    exalted512 wrote: »
    -Cody
    Thank you for the kind advice. I will keep that in mind.
    Always enjoy reading comments.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited March 2010
    Honestly I talked to many different people first off.
    Than read some articles, some were not complete in what to do and others were just to complex.
    My own words take your time do not rush and let the resin cure in between coats.
    Fiberglass mat is the way to go for what to use. I prefer it over the whisker stuff.
    Here are a few links.
    THIS ONE after the curing lay down a layer of mat overtop of the fleece.
    http://phoenixphorum.com/how-to-build-kick-panels-vt287.html
    http://www.ehow.com/how_4609577_custom-kick-panels.html
    A few other tips, layer up the aluminum foil before you start your base. Also when you put the fleece or matt on, stretch the stuff do not let it sag.
    If you have questions please ask.
    This place was a bit to much for me but still some good info.
    http://www.fiberglassforums.com/
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited March 2010
    Sub box in and got the rca's wired to the proper wires.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited March 2010
    Okay it is....3 A.M. I am tired and half asleep. Considering I had to run errands and was out for almost 3 hours I think I did a lot of work. A friend of mine is away and was kind enough to let me use there garage, as I already house sit. SO picture time.
    What the dice and navtv will be wired so the video will also go to the head rests.
    Head rests power wires
    Powered up
    OH a QUARTER!
    Removing the rear deck speakers and box so the subs will be able to push air into the cabin.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited March 2010
    Where things are going to be ran threw to the trunk
    Getting darn time to pull her in for the night shift.
    Bondoed the kick panel lots of sanding to do tomorrow.
    Had to run another wire threw the door for the woofer being in its own area.
    Crossover all wired up.
    Bracket made and painted.
    Soldered up
    Mid installed
    Right door all back together.
    Left front wires ran.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited March 2010
    Well taking a little break so more pictures.
    Sanded the kick panel down have to fill in a few spots.
    Left side crossover and speakers installed.
    Back together.
    Started the amp rack
    Will probably put two fans one on each side one in and one out for cooling.
    Upgraded the ground wire.
    Started the left kick panel, going to be a little more complex with the hood release and trunk release button.
    Taking a break
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Sherardp
    Sherardp Posts: 8,038
    edited March 2010
    Nice thread Big A, I saw BMW and started reading the write up from the beginning. Your skills and attention to detail are pretty awesome bro. Keep at it. Looks very good.
  • audiobliss
    edited March 2010
    A lot of progress made so far. Lookin' good! Keep at it!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • bigaudiofanatic
    edited March 2010
    Routed all the speaker wires to the trunk
    Re did the false floor
    Tonight I did wire everything up for a audio test. Sounds amazing plenty of bass as well as crystal clear highs. Tomorrow I will sand primer and paint the pods and intall them.
    Still to do:
    Install rear camera
    Paint and permanently install the pods
    Wrap the sub box and floor install plexi glass and neon lights
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited March 2010
    Today has been a bit busy, my father was suppose to deploy for Iraq today but after getting there and waiting 2 hours they had to delay it until tomorrow. Just got back home and will try to get a few things done today even though 5 hours was killed. Just a bit off subject but here is me and him.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • TakeTheTime
    TakeTheTime Posts: 249
    edited March 2010
    Looks good in the back of your car, dood! :)
    Pioneer P88RS-II | Polk Audio SR5250 | JL Audio 12w6v2 | 2x Genesis 3 Stereo 100 | Genesis 3 Monoblock
  • bigaudiofanatic
    edited March 2010
    To be honest did not get much done today. Between this morning and having to study for a math test tomorrow coming back from spring break, I got a few things done.
    Got the left kick panel started and the right one starting the paining.
    Mounted the fuse block
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited March 2010
    I only wish it was my car.:D
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • audiobliss
    edited March 2010
    I need an update! I'm suffering from BMW-install update withdrawal!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • bigaudiofanatic
    edited March 2010
    audiobliss wrote: »
    Will see what I can do for you. Things are slowing down as of right now. Today will probably install the rear camera and work on the left kick panel. The thing is going to be a bit of a pain to wrap and contour. The dice we are waiting for a harness from the bmw dealer for the ipod audio to work. And the carpet should be here tomorrow. :p
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited March 2010
    Yesterday and today starting to finish things up.
    Power wire ran
    iPod cables ran, one is for video and audio the other is for just audio and can be controlled threw the head unit.
    Left kick panel going to require some work but will get it done. The hood release and all is a pain to work around.
    Wrapped the right panel.
    Just a note the metal grill will be put overtop of the speakers.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited March 2010
    Got the mat laid on the left panel today will sand it bondo and carpet it.
    The trunk got wrapped, the top lip where the indent starts will be shaved for the plexi glass. That is why the carpet there is not defined cleanly.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited March 2010
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • audiobliss
    edited March 2010
    w00t! Coming together, for sure!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Lowell_M
    Lowell_M Posts: 1,660
    edited March 2010
    Nice install. THanks for the Clear Glide product placement! (I'm the product manager for wire install products at IDEAL)
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • bigaudiofanatic
    edited March 2010
    Not a problem I use to use armor all but this stuff works much better, and does not get tension in a pinch of the rubber.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • domflane
    domflane Posts: 653
    edited March 2010
    Nice install BAF, I can't wait to see it all finished. You do good work bro . .
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • bigaudiofanatic
    edited March 2010
    Worked on the kick panel yesterday, going to clean up with some more bondo and sanding. than wrapped. The trunk and hod release are difficult to work around.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited March 2010
    Been 3 weeks going back to him this thursday. He is fine with it and very understanding that I go to school 4 days out of the week and that I do not own a garage. Very good guy, if I did not go to college and had nice weather I would of been done in about a week and a half.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
