Laserdisc Dynamics vs Blu Ray
LD was fantastic, but so is Blue Ray, especially when getting older.
Even regular DVD movies play better on Blue Ray.
But, even though Vinyl has some better qualities, it also has less desirables too, just like LD. Reel to Reel was also great. And so was Beta.
I put a Blue Ray Burner in my PC, and when I watch movies, watch through the PC ( sometimes ) and with the upscaling of the receiver I have, that helps even more. So, to do a side by side comparison, one would really need a non upscaling set up, which is rare with clean power and replaced output transistors and capacitors, etc.
Online streaming and external hard drive is the replacement to all of these technologies, and with the right programs running, little difference is heard, for me anyway.
I know I am not getting it all with my equipment, but I am getting better than many with the fact that I have Polk's to begin with.
Right now we are listening to BNL on the old VCR/DVD setup ( Talk To The Hand - Michigan ) and it sounds incredible.
My 2 cents, I wish you the best in your research.Onkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar -
DigitalVideo,
PCM takes up more space hence the need for lossless compression.
Isn't Dolby True HD lossless but also compressed bitstream but with a lower bit rate? Is there a difference in quality of sound between LPCM vs Dolby True HD and which is superior to have on a bluray disc? -
What I hear the primary complaint of LPCM is that it hasn't been used to deliver the full quality of master audio tracks, due to space and bandwidth concerns.
The DTS-HD MA and TrueHD lossless compression formats can deliver full 24/48 master quality audio in about the same bandwidth and space as LPCM at lower 16/48 fidelity.
There's some debate whether LPCM at downconverted 16/48 fidelity is really an improvement over 24/48 DTS @ 1.5Mbps (lossy). In some situations, it may be an improvement, and it others, it may be worse. Providing the full 24/48 audio master does away with such questions, because nothing is more faithful to the master than the master itself. Unfortunately, 24/48 LPCM requires more bandwidth than is available with most titles on BD25, and even some BD50 titles with MPEG-2. That's where DTS-HD MA and TrueHD come in; those codecs can losslessly pack the 24/48 LPCM stream, saving significant bandwidth and space.
A disc that can fit full LPCM compared to Dolby True HD the edge goes to LPCM from looking at the numbers. -
This could be an answer for more space on bd discs:
Pioneer Increases Disc Size to 500GB
http://www.blu-ray.com/news/?id=1616
http://www.xbitlabs.com/news/storage/display/20080806034009_Pioneer_500GB_Blu_Ray_Disc_Becomes_Feasible.html -
Your comparison of LD to DVD goes against every real world experience I've encountered. DVD is a compressed lossy format end of story. LD PCM is not compressed end of story. I can agree about dynamic range but the word length is compressed. Have you done side by side comparisons? I ask simply because that's what this thread was entirely about since I created it.
Okay, but again... you're talking only 2-channel PCM here, which means that only does you any good for movies before 1985 and the advent of Dolby Digital with Batman Returns. Barring the occasional full bitrate DTS track, DD 5.1 surround tracks on laserdisc are 384k variable AC-3 and require frequency demodulation to derive the AC-3 track from the right channel of the PCM track, whereas most DD tracks on DVD are 448k variable. Not that it's a huge difference from the theater, because 35mm prints use a fixed rate of 320k on the optical track.
But to anyone willing to do side-by-side comparisons, good luck. While you might find preferences over certain DVDs, I doubt you're going to find a single instance where the CD-quality audio of a laserdisc can top the master-quality audio of a Blu-ray. When you consider the noise reduction applied to laserdisc tracks and the lower dynamic range, there should be no comparison. And since your original post was predicated on the notion of "home mixes" that Blu-ray doesn't even use, that makes it even less likely that you're going to find a 2-channel PCM track that sounds better than a lossless track from the masters, any more than you're going to find a CD that sounds better than the 2-channel SACD.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
kuntasensei wrote: »Okay, but again... you're talking only 2-channel PCM here, which means that only does you any good for movies before 1985 and the advent of Dolby Digital with Batman Returns....
http://www.zonadvd.com/imagenes/analisis/batmanvuelve_bluray/audio_ing_dd51.gif
http://www.zonadvd.com/imagenes/analisis/startrek2009/audio_ing.gif -
Okay... was there a point there that I missed?Equipment list:
Emotiva XPA-3 amp
Any of you familiar with Sony Dynamic Digital Sound (SDDS) and why and how it was created and what benefits it offers, and what is the difference between SDDS and Dolby/DTS? I do know that Last Action Hero was the first movie to use it.
LD has INCREDIBLE dynamic range. More than DVD for sure but I don't know how it would go compared to BD.
I have a small collection of LD's and was a big fan of the format up until the mid 90's.
I've always liked the sound of LD. When things start exploding, it gets real loud. I think my Jurassic Park LD has more dynamics than any DVD or BD I own.
Digital,
SDDS is a format used in movie theatres. I"m not sure if it's still being used today, but back in the day, SDDS equippped movie theatres would include 2 extra main speakers located between the L and C, and R and C channels. So a pan from extrme left to extrme right would go something like this:
Far Left-->Left-->Center-->Right-->Far Right. That's not taking surrounds into account. -
kuntasensei wrote: »Okay... was there a point there that I missed?
+1
"Originally Posted by kuntasensei
Okay, but again... you're talking only 2-channel PCM here, which means that only does you any good for movies before 1985 and the advent of Dolby Digital with Batman Returns...."
Saving Private Ryan and Batman -
+1
Yeah, I saw the graphs... but how does that contradict what I said? You're showing graphs of 448k Dolby Digital for SPR (which Laserdisc can't hold - AC-3 on Laserdisc is limited to 384k) and Batman Returns (the first Dolby Digital movie). What is the point of showing me that?Equipment list:
Emotiva XPA-3 amp
Digital,
I read how the movie Last Action Hero was the first to use SDDS and they talked about how loud it was before I saw it in the theaters and when I went to go see it I remember how loud and over bearing it was at times, it was relentless, I started to get a head ache. Still the loudest, most intense movie for sound I ever heard in the theaters.
Is there any way for a home theater to take advantage of SDDS? -
kuntasensei wrote: »Yeah, I saw the graphs... but how does that contradict what I said? You're showing graphs of 448k Dolby Digital for SPR (which Laserdisc can't hold - AC-3 on Laserdisc is limited to 384k) and Batman Returns (the first Dolby Digital movie). What is the point of showing me that?
Only express that I share your opinion and I agree with you. Good comment. -
Equipment list:
Emotiva XPA-3 amp
digitalvideo wrote: »I read how the movie Last Action Hero was the first to use SDDS and they talked about how loud it was before I saw it in the theaters and when I went to go see it I remember how loud and over bearing it was at times, it was relentless, I started to get a head ache. Still the loudest, most intense movie for sound I ever heard in the theaters.
Same here. I saw Spawn in SDDS and it was way too loud and piercing. I guess when you have a loud passage in SDDS, it gets louder because there are more speakers in the front.
I don't know if a HT can take advantage of SDDS or not. I can't remember if the extra tracks are discrete or matrixed. You'll probably need a cinema SDDS processor if you want to try it at home. -
I'm still curious to Headrotts direct comparison. Most people I've spoken with have said LD sounds more dynamic and better then certainly DVD. I'm curious how much better BD is...the numbers mean something but not if real world experiences are different. CD was initially perfect sound, 20 years later we know that wasn't the case.
Any of you familiar with DTS Neo:6 ?
digitalvideo wrote: »Any of you familiar with DTS Neo:6 ?
Yes. And I can't stand it. It's basically DTS' equivalent technology to DPL-II, but unlike DPL-II, it introduces audible artifacts and harshness that make me want to jam a screwdriver in my ears. I don't use it under any circumstances.Equipment list:
Emotiva XPA-3 amp
Ok, I hate to derail this thread...but I gotta!
kuntasensei (or anyone else), is there a place that lists those types of presets and which is best for what?
Which one do you prefer (if any)?"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
If you have a 5.1 system, stick with the native 5.1 track with no additional processing. If you have a 7.1 system, I recommend DPL-IIx for 5.1 tracks full time. If you have a 9.1 system, DPL-IIz height is great (better than Audyssey's DSX, in my opinion). If you're talking stereo music, purists will tell you stick with stereo/direct. I use DPL-IIx Music Mode and quite like it, but there's no right or wrong there.
Again, which is "best" is personal preference. DTS: Neo6, however... AWFUL. It makes things sound shrill and creates some bizarre audio artifacts, whereas Dolby's goal with DPL-IIx was to leave the source unaltered other than steering it to the channels based on the phase/amplitude relationships present in the existing audio.Equipment list:
Emotiva XPA-3 amp
Kuntasensei, do you prefer Dolby TrueHD or DTS MA when watching bluray? Can you tell any differences between the two?
digitalvideo wrote: »Kuntasensei, do you prefer Dolby TrueHD or DTS MA when watching bluray? Can you tell any differences between the two?
Honestly, they sound identical to me. I have a couple of Blu-rays that have both tracks, and if I switch between them with my eyes closed, I can't tell a difference. I guess master quality = master quality, regardless of the compression.Equipment list:
Emotiva XPA-3 amp
I find that DTS MA is recorded slightly hotter than Dolby TrueHD.
Thanks to this thread, I'm getting a better LD player. Found a local gear collector who's selling LD players. Can't wait to enjoy my LD's again. -
You should get the LD-S2. It is by far the best player I've seen and heard. It does not due the auto-flip feature (which is a greater cause for failure, although is not as convienent but it's a reason to get up and move a little). I have owned about 10 different LD players and have watch about 30-35 others and the LD-S2 is one of the best. Just a recommendation if you are going to buy another player.
I still need to hook mine upand do the comparison. Sorry it's taking so long, I am just short on time. I will get to it though.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Greg,
Thanks for the heads up. I'm not sure what models he has but I'll have to check. I don't want to use my Pioneer because it doesn't have S-video out.
Here's what I'll do. I'm going to get a good LD player and do a direct comparison with my PS3's BD audio because it can convert the multichannel high res into 2ch. I don't have 5.1 anymore. Both units will run in 2ch. My current 2ch set up blows away my previous 5.1.
I have several movies which I own both on LD and BD:
The Rock
Twister
I will post my experience.
Here's something interesting.... Caution: this video is very retro. The 90's look can look very shocking or very funny today. http://www.youtube.com/watch?v=pk46j_dj_Os -
Hey Organ,
I wouldn't worry about S-Video output. LD was a composite format, most players will look better using the composite instead of the S-Video. The comb filters used with most S-Video outputs on LD are historically very poor. Most LD guru's would tell you to stick with good ole' composite. -
They're actually at the same level. TrueHD just has a dialnorm parameter that changes the global volume, whereas DTS MA doesn't. If you account for the dialnorm, they're identical.Equipment list:
Emotiva XPA-3 amp
I no longer see the DTS-HD or TrueHD logos when i'm watching movies (I used to when I first got it), even though both my blu-ray player and my media server are both set to bitstream. If I don't see those logos, and only see the Dolby DPL-IIx symbol, am I not really getting DTS-HD/TrueHD?"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
ryanjoachim wrote: »I no longer see the DTS-HD or TrueHD logos when i'm watching movies (I used to when I first got it), even though both my blu-ray player and my media server are both set to bitstream. If I don't see those logos, and only see the Dolby DPL-IIx symbol, am I not really getting DTS-HD/TrueHD?
It just means that you're applying DPL-IIx to those formats. My Onkyo shows DPL-IIz on the display, with very small DTS-MA or TrueHD symbols, but if I hit the display button on either my Oppo or my Onkyo, it shows the format being played.Equipment list:
Emotiva XPA-3 amp
kuntasensei wrote: »It just means that you're applying DPL-IIx to those formats. My Onkyo shows DPL-IIz on the display, with very small DTS-MA or TrueHD symbols, but if I hit the display button on either my Oppo or my Onkyo, it shows the format being played.
So, even though DPL-IIx is being applied, i'm still getting the benefits of those formats?
I really wish I had the money to have someone come calibrate my system. I love audio/video and the equipment that goes with it, but when it comes to understanding all the small tweaks/tricks...i'm lost."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
