Dual subs
krauley
My avr has only one pro out for the sub/lfe channel and im wondering if i wanted to use a 2-sub set up, could i just use i splitter for the sub cable to two subs? would using a splitter degrade the signal? right now im using a single sub but wanted to investigate more for the future. thanks
Onkyo 808
Emotiva XPA-5
Polk Audio M70s fronts
Polk Audio Cs1 center
Polk Audio 50s surrounds
Polk Audio 30s backs
Polk Audio Psw505 sub
Polk Audio Psw10 sub
Oppo BDP-93
PS3 slim 250gb
Vizio 55" Led-lcd
HTPC Evga P55/Intel i7-860/Evga 260 Sli
Emotiva XPA-5
Oppo BDP-93
PS3 slim 250gb
Vizio 55" Led-lcd
Post edited by krauley on
Hello Krauley,
That would be no problem, just use a RCA type "Y" cable and send a second signal to the additional sub-woofer.
Regards, Ken -
Y rca cable is the way to go!Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
I see you have a PSW10 sub, I ran 2 of those for a little while, sounded decent once I got them set up ok, problem with the PSW series for H/T use they tend to get a little lost below 35hz, other than that I liked it. DavidPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Make sure you get the phase correct with two of them. They can effectively cancel each other out.
Two of them are very particular to placement. -
Vette C6.r wrote: »Two of them are very particular to placement.
Got that right, I think Ive seen every square inch of my living room carpet..................up close.:pPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
great replies guys, i was just worried there could be some kind of signal loss by splitting but i agree with the "Y" working.Knucklehead wrote: »I see you have a PSW10 sub, I ran 2 of those for a little while, sounded decent once I got them set up ok, problem with the PSW series for H/T use they tend to get a little lost below 35hz, other than that I liked it. David
yes i was watching the mist a few days ago and during one scene with a lot of shaking going on my sub completely let me down. it went into a rattling fit because i problably had the volume too high on it. other wise it has been a decent first SW for me.
well that is now history, i pulled the plug on the psw505 today from newegg so i hope i can expect better results from it.
this leads me into another question if you guys dont mind. with the new 505 coming i have no use for the psw10 other than selling it or using it as a second sub. ive read that having two different power rated subs is not going to work real well. so what are your thoughts on that: psw505 up front with m70s and the psw10 in back with m30s?
also dont tell the wife, shes gonna kill me :eek:Onkyo 808
Emotiva XPA-5
Oppo BDP-93
PS3 slim 250gb
Vizio 55" Led-lcd
HTPC Evga P55/Intel i7-860/Evga 260 Sli -
Kenneth Swauger wrote: »Hello Krauley,
Regards, Ken
Y-cables are not the way to go. The signal is always degraded. I have tried Y-cables several times with crappy results. You can A-B it yourself for kicks.
My recommendation is to use the left and right preouts for the front channels to feed your sub. Use the subs crossover to filter frequencies above 80hz or whatever your prefer. This will give you the best integration and the best sub bass. Make sure your run your left and right front speakers as large.
Mike -
SolidSqual wrote: »Y-cables are not the way to go. The signal is always degraded. I have tried Y-cables several times with crappy results. You can A-B it yourself for kicks.
Mike
I use shielded "Y" splitters all the time for 4 subs and never, ever have had a signal degrad with them. If you use a cheap brand Rat Shack "Y" splitter, then that could be a possibility. If the "Y" cabel is shielded, then no degradation.
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
Good choice....I was looking at the specs for the 505, looks like its good down to about 23hz...not bad. I have seen people do this, I guess you could use the PSW10 as a mid-bass, if you decided to do what SolidSqual said in his post you could cross the 505 at 80 and the PSW10 at a higher freq....or......piss your wife of really bad and buy another 505.:pPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Knucklehead wrote: »Good choice....I was looking at the specs for the 505, looks like its good down to about 23hz...not bad. I have seen people do this, I guess you could use the PSW10 as a mid-bass, if you decided to do what SolidSqual said in his post you could cross the 505 at 80 and the PSW10 at a higher freq....or......piss your wife of really bad and buy another 505.:p
Oh how i wish i was man enough to do that!
Thanks for the help guys. ill probably just set the psw10 aside for now and get the 505 set up and see what i got first.
Onkyo 808
Emotiva XPA-5
Oppo BDP-93
PS3 slim 250gb
Vizio 55" Led-lcd
I'm running 2 505's with a splitter and they sound great, someday they will be replaced by a couple svs subs.
Let us know how it sounds.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
will do, sub comes monday so if i dont reply by tuesday that means i didnt get the sub by her and i leave all my hardware to science :POnkyo 808
Emotiva XPA-5
Oppo BDP-93
PS3 slim 250gb
Vizio 55" Led-lcd
Bill
I've used Y-splitters from Blue Jeans Cable, Signal Cable and even Cardas. In my experience, the overall volume of the signal is reduced with a splitter and bass becomes more sloppy. Whatever works for you works for you, I just prefer using the pre outs to drive dual subs. To me it makes more sense in a system. -
SolidSqual wrote: »I've used Y-splitters from Blue Jeans Cable, Signal Cable and even Cardas. In my experience, the overall volume of the signal is reduced with a splitter and bass becomes more sloppy. Whatever works for you works for you, I just prefer using the pre outs to drive dual subs. To me it makes more sense in a system.
Either way...the OP's AVR(Onkyo 604) doesn't have preouts...so a Y splitter would really be the only option to run dual subs on that AVR.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Good luck on your stealth delivery, krauley. I just replaced a PSW350 with the PSW505 (also from NewEgg) and certainly can tell the difference.
-bruce -
BruceOrlando wrote: »Good luck on your stealth delivery, krauley. I just replaced a PSW350 with the PSW505 (also from NewEgg) and certainly can tell the difference.
-bruce
Cool, thanks. Im going to get busted though, my ups driver also comes thru the area between 3 and 4pm expect when im expecting a delivery, then he comes after 6pm. My wife will get here at 5:30 and ill get busted. i think she has a deal with him or something but i guess its my fault for being underhanded. but as i read somewhere in these forums..."its easier to get forgiven then to get premission". a motto i live by, at least until we get a new ups guy
Onkyo 808
Emotiva XPA-5
Oppo BDP-93
PS3 slim 250gb
Vizio 55" Led-lcd
I feel your pain, as I do believe that sometimes it is better to beg for forgiveness than to ask permission. Discussed the new Monitor 60's and 30's with the wife, and I pointed out the new Pinpoint mounts for the 30's -- but the new sub I just sort of slipped in there. The PSW350 was big and black, and the new one is just a little bigger.
I work at home, so deliveries aren't an issue. However MY UPS guy, John, lives across the street from us. So if he ever asks, "hows the new sub?" in front of the Mrs., I'm a goner.
-bruce -
I really dont "keep" anything from my wife! all she has to do is ask!
Ive got my 505 hooked up but now im waiting on a empty house to beable to tune to my liking, so far im a happy polker:DOnkyo 808
Emotiva XPA-5
Oppo BDP-93
PS3 slim 250gb
Vizio 55" Led-lcd
