finish on ls50
j allen
j allen Posts: 363
edited March 2010 in DIY, Mods & Tweaks
So, I picked up a pair of ls50's listed on the deals of the day sticky. They are overall in pretty good shape. The only thing I absolutely need to do is replace the vinyl on the fronts, as it is peeling and slightly torn.
My real question is: will the finish on the sides and top take a high gloss varnish without any adverse effects? I feel like they would look a lot nicer in my living room if they had a shinier look to them. (I think all electronics should be large, black, and SHINY)
Thanks in advance for any responses. I can migrate over to the vintage forum with this if it's more appropriate.
Post edited by j allen on
  • Rodeo0530
    Rodeo0530 Posts: 797
    edited March 2010
    I'm of no help to you on this topic, but I'm glad to see that you got these speakers. I would have loved to have snagged them, but I'd probably be in the dog house right now...sort of am anyways for buying a new TV and AVR in the last week, but that's besides the point.
    Hopefully someone here will be able to give you some good ideas!
    Front - Polk Audio Monitor 70
    Center - Polk Audio CS2
    Rear - Polk Audio TSi 100
    Sub - Klipsch rw-10d
    AVR - Onkyo ht-rc180
    Main Amp- Parasound HCA-2003
    Surround Amp- Sonance Sonamp 260
    Tuner- Parasound tdq-1600
    Turntable- Pro-ject Debut III USB w/upgraded platter
    IPod dock - Pure i20
    TV - Panasonic Viera tc-p46g10
    Sony Playstation 3(250GB)
    Nintendo Wii
    Power Conditioner- Panamax 5100
    Not in use-
    Polk Audio Monitor 60
    Polk Audio PSW10
    Parasound p/sp-1000
    F1nut Posts: 51,751
    edited March 2010
    You should not apply a clear coat finish on top of another clear coat finish unless you know what the original finish is. In this case, I believe the original finish is lacquer. As such, you cannot apply varnish over top of lacquer. Now, as long as the original lacquer is in good condition all one has to do to obtain a high gloss sheen is to use progressively finer polishing compounds such as those made by 3M. You will also need a variable speed buffing machine and the appropriate buffing pads. However, none of this is cheap. It would be more cost effective to have them buffed out by a local refinishing business.
    Depending on the original veneer used it may have pores that have not been filled. In that case, buffing the finish to a high gloss sheen will not look very good.
  • j allen
    j allen Posts: 363
    edited March 2010
    Thanks F1nut. Now that I actually think about it, it certainly makes more since for it to be a lacquer, since it pretty well obscures the color of whatever kind of wood they used underneath it. I half wonder if the previous owner 'touched them up' with a can of black paint, since they tried to hide the damage to the vinyl with electrical tape. (and it [the veneer] seems awfully thick) I suppose I could try to remove the original veneer and replace it with something I could finish however the hell I want. These things sound really nice, so I'm hoping I can get their looks to match it.
    And for what it's worth, the manual implies that only the ls90's actually have a good quality veneer that can be polished up nicely. Of course, I could be missing something or reading into things too much there.
  • greyford1979
    greyford1979 Posts: 749
    edited March 2010
    Congrats on buying them!!!!
    I love animals, they're delicious!
  • j allen
    j allen Posts: 363
    edited March 2010
    Update: I'm completely refinishing the things, as I am a sucker for projects that cause me to hurt my fingers. The ones I got have what I would call the cheap finish option (cheesy fake wood-grained black vinyl). At this time, one is completely naked, and the other is about 60% clean. I had to stop and tear down my makeshift workshop because we had company over last night, but I'm hoping to have them both stripped by tomorrow night. I'm going to be ordering some sort of veneer in the next week or so, and I'll put up a new thread with before and after pictures when all is said and done.
    As long as they are apart, is there a good 'drop in' replacement for the sl2000 tweeters? They seem in good shape, but just aren't quite as crisp as they could be.
    cheers,
    j
  • ken brydson
    ken brydson Posts: 9,002
    edited March 2010
    j allen wrote: »
    cheers,
    j
    LS50's don't have sl2000's. Are you sure that's what is in there? If so, someone put in the wrong tweets.
  • j allen
    j allen Posts: 363
    edited March 2010
    You're absolutely correct. I misread the part number on the tweeter. They're SL6000. I think I just read 2000 because I've seen those mentioned a lot on here. Feel free to give me a textual slap to the back of the head :)
    Either way, it still seems like the tweeters don't keep up with the drivers in these guys as far as sound quality is concerned.
