Projector: Screen or Wall? Easy!
joeparaski
joeparaski Posts: 1,865
edited March 2010 in The Clubhouse
This decision will be the easiest one yet if I go with a PJ......SCREEN!!!
Why?
Because I'm repainting the bathroom. I had to so some patches here and there and then the wall needed to be sanded.
We are in the year 2010. We sent man to the moon over 40 years ago. And nobody has invented a product that doesn't need to be sanded resulting in white freakin' dust up your nose and every other nook and crannie in the immediate area!! ><(*#$%&()*%&#)(.....Jesus H. Christ!!!
Prepare the wall for a screen????....over my freakin' dead **** that's gonna happen!!!
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
  • Sherardp
    Sherardp Posts: 8,038
    edited March 2010
    Nothing really to prepare. The screens are easy to assemble with just a screwdriver. The matte white material simply snaps onto the frame. The brackets are mounted on the wall and the screen hangs on the mounts. Takes about 30-45 mins. You don't have to paint your screen wall or any of that if you don't want. That choice is up to you.
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2010
    Sherardp wrote: »
    +1 mine was up in about 45 minutes and two six packs of sam adams. :D:D:D:D one for me and one for my helper LOL...
    Amp: sunfire cinema grand signature 5ch 425 wpc
    Side surround amp: Sunfire 2 X 300
    Processor: sunfire theater grand V
    Fronts:: polk sda-srs 1.2
    Rears: Polk LSiFX
    Side surrounds: Fxi5
    Center: (2)polk LSiC's
    Sub: svs pb-13 rosenut
    Hd-Dvd: toshiba xa-2
    Blue Ray: oppo bdp83se
    Projector: sony vw60
    Screen: Da-Lite 106"
    APC S20 Power conditioner
  • nadams
    nadams Posts: 5,877
    edited March 2010
    If you're good at mudding, you can put on just the right amount that you wouldn't hardly need to sand. I, am not good at mudding.
    This is why my bathroom walls have been unfinished for 2 years.
    Ludicrous gibs!
  • joeparaski
    edited March 2010
    Sherardp wrote: »
    What I meant was that I don't want to prepare the wall as a screen. I did watch a video on assembling a fixed screen...now THAT I don' mind.
    Joe
  • BeRad
    BeRad Posts: 736
    edited March 2010
    I hear you on pre-painting prep work. When doing the drywall in my living room I actually had a very nice complete breakdown. I absolutely lost it, and it was the second time in my life that has happened. Lesson learned: PAY A PRO!
    I'll patch and do minor work, but if it takes more than 2 hours.... GAWD sanding is something I would rather do without! If going projector I'd personally go with a motorized screen I think. It would be nice to hide it when not needed.
  • Sherardp
    edited March 2010
    joeparaski wrote: »
    Joe
    Oh ok, now I'm tracking Joe. Hey were you able to get with projector people in regards to viewing the PJ in your home.
  • BIZILL
    BIZILL Posts: 5,432
    edited March 2010
    get the projector first. mount it via shelf or ceiling mount and THEN choose your screen. i was about to pay for a 125" screen but when my projector arrived i realized i could easily fit a 137". i've never read one instance where the owner wishes they went smaller.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • engtaz
    engtaz Posts: 7,669
    edited March 2010
    BIZILL wrote: »
    I 2nd this.
    engtaz
