Tube Microphonics
HBombToo
I do believe I understand this phenomena. I hear it on an SACD that contains 1 of my most favorite artists, Stevey Ray trck 12. Sounds amazing but I can hear it. I don't have the same redbook cd for a comparison but if I did... my perception could start another hall of shame entry:D
in my understanding microphonics(mp from here going forward) is feedback between the grid and cathode started by sound pressure.
Twin:D
i just turned on the keep alive:rolleyes:
i guess i should have done another 70/150 post
Twin:D
***WAREMTAE***
Post edited by HBombToo on
I still can't hear it with my tubes but I'm sure it's there. All tubes are microphonic. What does it sound like on your system? If it's bothering you, there are a lot of tube dampening devices out there. Russman bought some for his pre amp tubes.
Maurice -
Forgot to ask...Are you using a tube pre or amp? It's not listed on your signature. What brand/model#?
Maurice -
I can start it at will by tapping the 6dj8's in my Audible Illusions Modulus. I hear it loud and clear over an sacd played on my solid state HT. Stevey Ray Vaughn track 12. or something like that.
Twin***WAREMTAE*** -
How long have you had the 6DJ8's for? They've probably gone bad or are on their way out. Tubes become very mp when going bad. When my JJ pre amp tube went bad it became very mp and a light tap was clearly audible throuh the speakers. I tried tapping on my pre amp and power tubes and didn't hear anything. You might want to try a new set of tubes. Very nice amp btw.
Maurice -
Originally posted by organ
1.)Tubes become very mp when going bad.
2.)Very nice amp btw.
Maurice
a gas leak is the killer.
Thank you but the jury is out while i'm in repair mode
I can hear some microphonics when I tap on any of my tubes. Lets see, that would be about 49 tubes. I don't think they are going bad. A lot of it probably depends on the other associated electronics. Many use vibrapods or similar under their tube amps and preamps to keep floor/stand vibrations away. If the sound level is high enough for air borne vibrations you can use brass rings on the top of each tube. I forget who sells them.
OK, I just check all my tubes again....The only ones that are mp is the pair of 7199 driver tubes on the Dyna. I still had to tap them pretty hard with my finger nail to hear anything from the speakers and it was barely audible. No mp on the other tubes though.
Maurice
