PS3 only player
wayneniamat
I'm guessing I'm not alone, unexpectedly rediscovering 2-channel music while building a multi-channel home theater on a shoe-string budget.
I'm using a 40gb SONY PS3 which does NOT play SACD as my player and I'm stuck with that for now.
I've taken to converting flac files to .wav for playback from the ps3.
Is there anyone else in this stage of evolution? I'm consumed with finding the highest fidelity 2ch and multi-ch content that I can play on my 40gb ps3.
What's out there?
What's out there?
Post edited by wayneniamat on
I'm using my laptop with flac right now in my rig. Sounds great.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Using my laptop with music ripped in apple lossless going threw a usb dac sounds great as well.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Yeah I need to find a new USB dac, using a creative MP3+ right now.
It's useful though, I take it outside and attach it to my "ghetto blaster" and it works well.Main Surround -
Have you tried just putting CDs in your PS3 and playing music like that?
concealer404 wrote: »Have you tried just putting CDs in your PS3 and playing music like that?
LOL, you are living in the stone age. That's the way I do it for now, but my 80GB does SACD, so I am getting ready to dabble in that soon.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
There are also some blu-ray concert and the rare blu-ray music only disk. Look for 24bit/96khz and 24bit/192khz blu-rays for the high quality stuff. The latter tends to be only classical and the like from companies like 2L.
Good point....that might be your 'best' sounding music....it might also help to put some better DACs between your PS3 and your AVR or whatever power source you're using......
I also use my laptop, google's PS3 media server and a higher end Onkyo AVR in the mix. But that's more for 'casual listening'....Of couse I record everything as a wav lossless file--and stream it to the PS3..
THANKS for the suggestions all. 'google ps3 media server'? So everyone's streaming. Hmmm.
You can also store files locally if you want. For 50 bucks or so you can change the internal hard drive out for a 320GB or larger one. Really depends on where you find most convenient for all your files. It can also access external drives via the usb ports. Just have to make sure the external drive is formatted fat32.
The ps3 internally uses generic SATA laptop size hard drives. There are plenty of 'how to' videos of how easy it is to change one on youtube. Basically pop the little plastic door off, unscrew one screw, slide the old one out, transfer the cage to the new one, reverse. Then the ps3 prompts you to format the new drive on boot up. A few extra steps are necessary if you want to save data from the old drive. -
I downloaded a file from NL2 that is 96khz and 24 bit but it isn't playing on my ps3. I tried toying with the MUSIC and SOUND settings but nothing doing. Any advice?
wayneniamat wrote: »I'm consumed with finding the highest fidelity 2ch and multi-ch content that I can play on my 40gb ps3.
Even if your PS3 doesn't play SACD (and I know the 40GB one doesn't) it still plays DSD Disc format. See http://www.ps3sacd.com/dsddiscguide.html
This may be the highest fidelity 2-channel media you can find. The only issue is that unless you record some yourself you will not have much content (yet).
