Fxi A6's or RTi A3's for rears
bevo
bevo Posts: 306
edited January 2014 in Speakers
My setup so far is in my sig. Which of these should I use for the rears?
Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra)
Post edited by bevo on
  • bevo
    bevo Posts: 306
    edited March 2010
    I should have added, upgrade something else to my poll. As a matter of fact, how much of a difference would a csi a6 make for me?
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Toolfan66 Posts: 18,064
    edited March 2010
    Ether one would work great.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2010
    It all depends on your room configuration.
  • Murray1
    Murray1 Posts: 193
    edited March 2010
    Bevo,
    I have a CsiA6 with my RTiA5's and love the sound. My room is quite large so I went with the 6. Guess your decision is based on how your 4 is handling your room size and config. I have yet to get my rears and have asked the same question as you regarding the FXi series vs RTiA3 bookshelves. Sure would be nice if some actual owners would chime in and share their input with us. Good luck and enjoy.
  • bevo
    bevo Posts: 306
    edited March 2010
    leroyjr1 wrote: »
    My room is 24x14. I sit in the front 2-3rds of the room dead center. In all honesty, I would go 5.1 now after hearing how much better the fxi a6's sound compared to the rm8's I had. The problem is that (I know this sounds stupid) I don't have room for a 5.1 but I do for a 7.1 . I set closer to the tv then my wife wants to, so I have a chair that I set in front of the couch when I watch and listen, and everything is setup for me because she couldn't care less about HT. The couch will not let me put a 5.1 setup in because it is in the way.
    For 7.1 I have 2 speakers beside me, and 2 behind the couch. If I went just 5.1 with speakers just behind the couch they are to far away for 5.1 but sound fine with 7.1. I've tried both setups and 7.1 sounds best.
    The rear speakers are farther away from me though then my sides or rears and I think an upgrade over the rm8's would really help the sound back there.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • renowilliams
    renowilliams Posts: 920
    edited March 2010
    Another option would be a pair of RTI6's. I have the same fronts as you and they match just fine. You may be able to get a great deal on a pair. As far as the center goes, I would get the A6. The biggerthe center channel the better IMHO.
    Good Luck
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited March 2010
    Murray1 wrote: »
    Bevo,
    Well - I still have my RTI4s as my surrounds in my 5.1 setup - sounds great!
    I don't have a multi-seat theater room - just a couch, and its mostly me that is 'critical' of sound quality, so direct radiating speakers work well - and since I do listen to alot of mult-channel music another reason for direct radiating surrounds.
    If you can get the RTIA3s from Polk Direct, then they are a fantastic bargain!
    So, your choice all depends on your setup and preferences.
  • Murray1
    Murray1 Posts: 193
    edited March 2010
    Erik Tracy wrote: »
    Can someone explain how multi channel music works. I listen to music in stereo 2 speaker mode thinking that that best duplicates a concert (musicians in front of me). Also would like to know if I should run my center speaker for music or stick with 2 speaker config. Thanks for your input.
  • Geoff4rfc
    Geoff4rfc Posts: 2,838
    edited January 2014
    Tungx2 wrote: »
    fxi a6 seems better overall, less directional
    Wow, this thread is only 4 years old........Hey bevo, you still trying to figure out which on to get??
    @ Tung, actually, the FXiA6 is multi directional where the A3 is a direct radiating speaker, nicely done here..........
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • Tungx2
    Tungx2 Posts: 58
    edited January 2014
    I was reading and researching to replace my RTi a9 rears. the conclusion is that rear surrounds shouldn't be very directional. you shouldn't have felt where it was "Exactly" coming from. So the Fxi a6 will be great for the side surrounds. for the rear surrounds, I'd recommend rit a1 should be enough. not much base is needed from the rears always, as you will be crossing them over around 80hz anyways.
    TV.......................Samsung 46" LCD LN46A550
    A/V Receiver.........Yamaha RX-V3900
    Amplifier.............. Emotiva XPA-1 Gen 2 for fronts, XPA-3 Gen 2 for center and Surrounds.
    BluRay Player.........Sony PS3
    Fronts...................RTia9 (modded)
    Center.............. ...CSiA6 (modded)
    Surrounds.............Empty for now. But waiting for a Fxi A6 deal on polk ebay.
    Rear Surrounds.... Deciding if front presence is the way to go instead.
    Sub..................... SVS PB12-plus/2
  • Geoff4rfc
    edited January 2014
    Tungx2 wrote: »
    I see the point you're tying to make, but then you contradict yourself. Unless, you're confused on what rear surrounds are.
    The A6 is not only good for surrounds, but for rear, or back surround speakers. As you state, you shouldn't feel where the sound is exactly coming from.
    The RTiA3 is a direct radiating speaker, coming from a direct source, the FXiA6 is a bi/dipole speaker, sound coming from a multiple source, hence, indirect sound.
    As far as crossing them over at 80hz, maybe that's what you cross them at instead of the infinite way you put it for the end all of set ups.
    And since you're in research mode, you can try this to better understand what you're trying to convey to the past of four years ago.
    http://www.polkaudio.com/polk-university/technology/bipole-dipole-surround-sound-control
    Set up:
  • Tungx2
    Tungx2 Posts: 58
    edited January 2014
    Geoff4rfc wrote: »
    I was trying to find info on bipole and dipole without much success. Those diagrams answered all my questions. Thanks!
    Hmmm I was just messaging someone about Rti a1 through craigslist too, lol. I guess i'll do fxi a6 on the sides and a4 on the rears. :)
    Actually, I can't wrap my head around this theory (even though I think it's true). Listeners shouldn't be able to pin point where the sound is coming from, so we use Fxi type of speakers. BUT would we still feel the sound of an airplane coming from behind to in front of us? Wouldn't the Fxi speakers muddy what the movie sound track was trying to achieve?
