Monitor 7 XO's
I just picked up a pair of Monitor 7 crossovers on ebay for $10.00. Would they work in a pair of Monitor 5jrs.? If so, maybe I'll try my hand at rebuilding them.
Hafler DH220 Power amp Recapped
Hafler DH110 Preamp Recapped
Hafler Digital FM Tuner
Virtue Audio M1 Piano CD Player
Technics SL-1210-MK5 with an Ortofon Black LVB250 Cartridge
Polk SDA1c's(Rebuilt XO's by Ben) RDO194 Tweeters
Post edited by gdphoto on
It all depends...there were several variations in the crossovers over the years.
That said, the 7's, 5's and 5Jr's all generally shared the same XO's.
Check the values on both of the crossovers, and if they match up, you should be fine. Just make sure that they're the same.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Thanks! That's a big help.Hafler DH220 Power amp Recapped
