What is the best function for LSiF/X?
I have complete set of lsi series such as lsi 25 for my L/R, lsic for center, two lsi9 for my surround speakers A/B, and one pair of lsiF/X for my surround back, and I use emotiva xpa 5/2 with denon 5308 as pre amp having 9.2 as my set.
However, I just want to know if lsi F/X is really designed for sound speakers or it will do a great job if it is assigned as sound back rather than surround speakers. I am willing to reassign my entire speaker set up for a better change.
Please advise me.
Please advise me.
Post edited by @@@@@ on
The LSiFX speakers can be set up in two different modes, namely bipole and dipole.
Each LSiFX speaker has a bipole/dipole switch to allow you to choose the desired setting.
For the rear surround position, the bipole mode is recommended for direct surround effects.
For the side surround position, the dipole mode is recommended for more diffuse surround effects.
I would suggest that you try the LSiFX speakers at the side surround positions and set them to dipole. Also check that the "right" speaker is on your right side and the "left" speaker is on your left side. The speaker "right" or "left" designation is shown on the back of the speaker. Move the LSi9's to the rear suround position.
If you want to retain the LSIFX speakers in the rear surround position, try setting them to "bipole".
See how that works for a few movies. Let your ears be the judge with your final setup.
Does this help?
I'll do everything you say and let you know the result soon.
Thanks though!!! -
What is Dipole and Bipole and how are they different.
LSi F/X®
This state-of-the-art bi-directional surround speaker delivers
effects so real they will astonish you. Engineered to match the
ultra-high performance of an LSi Series multi-channel system,
the LSi F/X uses the identical 5 1/4” drivers and Ring Radiator
tweeters as the rest of the LSi Series, for seamless integration
into your high-end surround system.
http://www.polkaudio.com/education/showanswer.php?question_num=45 -
I've also found the FX's sound better if the tweeters are placed at or just above ear level, Polk suggests you place them about 2' above ear level, for me this was too high.
Welcome to Club Polk!!!
Jimmy -
Jimmy
Thank you for your advice!!! -
LSi F/X®
the LSi F/X uses the identical 5 1/4 drivers and Ring Radiator
I really do appreciate your tips regarding my system. In fact, I've been learning a lot since I join this club. -
If you were in my shoes, what would be your surround back speaker, the lsi 9 or f/x?
Will depend on the acoustics of the room. I would try both to see the results.
http://www.polkaudio.com/homeaudio/lsi/index.php#lsifx
