Emotiva LMC-1 vs Carver C-1
PSOVLSK
I'm currently using my LMC-1 for two-channel after much thought about how to arrange my set-up. Have a chance to grab a C-1 for $150, but wasn't sure if the improvement would be worth it, or if it would even be an improvement in sound. Any opinions on these two units? FWIW, I prefer my H/K 7300 as a pre over the LMC-1 for music listening.
Post edited by PSOVLSK on
If you know the Carver is working fine, give it a shot. If you don't like it, sell it again for the same price.
Grab it... but if you can, get your hands on the Carver C-19 tube pre. Magic resides within that little black box.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
C-1 is a very good pre amp. $150 is a good price. If you don't like it you can get your $$$ back pretty easy.
nooshinjohn is right about the C-19. Though good luck finding one at a resonable price. There is one on Audiogon right now for $975. They range in price between $600 and $900 depending on condition.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
I honestly think you couldn't go wrong if you tried it out. the worst that could happen is you didn't like it. I'm quite sure you could recoup your investment.
Depending on what speakers you have in the mix, the C-1 has Sonic Holography which is similar to the SDA effect, if you have SDA speakers there's no point in having the SH and they sound weird used together. otherwise the C-1 is a nice pre that offers a lot of control, plus Phono inputs.
