Project/Screen setup dilemma (help)
joeparaski
I sent the 2.3 tl's upstairs and set up the SRS at the proper distance from the left and right walls (3' as per the specs). The distance between the SRS is 6'3" and the distance to the seating is 11'. In the corners are bass traps and dual SVS subs.
The problem here is to get a 100" viewing screen for a projector. If I leave the SRS at the required distance, I can't get that size. If I move the SRS closer to the walls, I'll lose something? SDA effect perhaps?
How close to the walls can I place the SRS without penalty and what is the required distance between them to get close to the 100" mark?
Or should I forget the projector and go with a larger plasma? (currently it is 52")
This is how it looks at the moment:
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
The closer you get to an equilateral triangle, the better effect. Six feet between and eleven to seat is out of whack. Stretch them out and see how they sound. Moving closer to the wall may or may not affect it as much as the long distance to seating area. Sound treatments on the walls at the first reflection may help and allow you the spread you need for the screen.
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Are you against having an Acoutically Transparent screen or are you planning a fixed frame screen? If you are ok with an AT screen that may be a good option for you.Shoot the jumper.....................BALLIN.............!!!!!
I intend to use the special paint and use the wall.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
Oh ok, got you now.Shoot the jumper.....................BALLIN.............!!!!!
