Laserdisc Dynamics vs Blu Ray
LuSh
I've done a lot of research lately on the merits of Laserdisc. A number of people have suggested that a Dolby PCM Surround track sounds much better then DVD and even in some respects better then Blu Ray.
I understand the DVD vs Laserdisc comparison because of the resolution and lack of compression found on Laserdisc in Dolby PCM and even DTS. What I've found interesting is that Laserdisc used Theatrical Audio Cuts while DVD and Blu Ray use watered down Studio mixes for the home. The theory being that many users will use cheaper speakers and television's as their primary audio sources. A Theatrical Audio cut offers better dynamics most cheaper systems couldn't endure, therefore the mix down.
Can anybody share experiences? Has anybody compared a Lossless Blu Ray presentation vs an older Laserdisc Dolby Surround cut on a decent setup? I'm not really curious on opinions but would rather hear from people who have actually done a direct comparison of Dolby TrueHD/DTS-HD vs Dolby Surround PCM.
Post edited by LuSh on
I have not done a direct comparison between Laserdisc and Blu-ray DTS-HD/Dolby TrueHD. I have between DVD and LD and the LD is absolutely better. I will have break out the LD-S2 and play a DTS LD through it and compare it to a DTS-HD or Dolby TrueHD soundtrack. Do you have any recommendations for comarisons (Live concerts, movies, etc.)?
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I have a couple of comparisons I'd love you to make. Some on DVD, some on Blu Ray.
Apocalypse Now LD (Dolby Surround PCM/ Red & White analog) vs. DVD Dolby Digital
Empire Strikes Back (AC-3 or Dolby Surround PCM/ Red & White analog) vs DVD Dolby Digital
Independence Day (DTS LD) vs Blu Ray DTS-HD
Die Hard (Dolby Surround PCM) vs Blu-Ray DTS-HD
Matrix (PCM) vs Blu Ray Dolby TrueHD
Braveheart (PCM/AC-3) vs Blu Ray Dolby TrueHD
Terminator 2 (PCM or AC-3) vs Dolby TrueHD
The Fifth Element (PCM or DTS) vs DTS-HD
Mission Impossible (PCM Surround) vs Blu Ray Dolby Digital 5.1
The Rock (PCM Surround LD) vs Blu Ray 5.1 PCM
Those are some ideas. I really think it would be a neat test. My understanding is that LD never compressed the dynamics found on Theatrical cuts, DVD and Blu Ray are watered down in terms of dynamics. This has nothing to do with resolution but rather the differences between the quietest passage and the 'big explosion'. I'm only working off of memory and it seems that there are many people who argue over this but few that have actually done the test. Many of those that collect LD will never buy Blu Ray (not really into the latest and greatest) and most of those that purchased Blu Ray were the first ones to ditch their LD for DVD. Let me know your findings I'm really interested to know. -
I love my LD's for sound over BluRay, but they are a PITA when trying to watch a feature length film(waiting for the flip and swapping discs) I would rather tolerate a sight loss of sound quality for the conveniance of not having to get off my **** to swap discs.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Lush,
I have some of the discs to compare in your list.
The Matrix LD Vs. Blu Ray
Braveheart LS Vs. Blu Ray
Die hard LD Vs. Blu ray
T2 LD Vs. Blu Ray
It would also be interesting to compare The Song Remains The Same LD Vs. Blu Ray, being as it's audio focused. Unfortunatley, there are different (audio/video) edits and I already know the master tapes used for the later (2nd) release of the LD, DVD and Blu Ray were deteriorated compared to the original LD, but it would still be interesting to compare the fidelity of them from a compression point of view. I'll hook up the LD-S2 probably this coming tuesday and compare. Maybe sooner.
Greg
I'd also be curious to see what the results of the same comparison would be if an interpolation mode was used for the DVD to compensate for the compression, for example, Sound Retriever available on Pioneer AVRs used in combination with Dolby Digital or DTS. (Then I'd be curious how DVD + interpolation mode compares to Blu-ray Dolby True-HD or DTS HD.)
Interpolation modes applied to analog sources don't usually help much, but they can sometimes improve upon digital sources that have used lossy compression. -
Could the studios put Theatrical Audio Cuts on bluray discs if they wanted too? And what would it sound like on a medium range HT system consisting of a decent reciever, amp, 5.1 speaker system?
Bluefox,
Yes LD is a very old technology that predates CD;' however it was marketed as the ultimate collectors format and was way ahead of its time. Vinyl is a very old technology as well.
Mon40CSMM10,
The Audio Retriever if I'm not mistake is an algorithm used to restore missing information or resolution. What I'm talking about is dynamics and not resolution. Not only did LD use PCM soundtracks (2-Channel re-encoded into multi) it also used (to my understand, I could be wrong) Theatrical mixes which were mixed specifically for film and movie houses. DVD/BD's are now usually remixed for home use. The idea is that most home playback devices are not up to snuff (Flat panel speakers, HTIB's) and the mix is tailored to these types of playback systems.
DigitalVideo,
I'm sure they could, however I don't believe they will. Again, I could be wrong. I started looking into this well over a year ago. I own a Blu Ray player but part of me always wondered. I watched a video on youtube that also perked my interest. I remember watching Apocalypse Now on Laserdisc and waiting for the DVD release. I finally bought the DVD and man what a let down. I understand Blu Ray should be better but I wonder about the differences in Dynamics. -
Bluefox,
Mon40CSMM10,
DigitalVideo,
I'm starting to understand a little bit more now. But isn't the purpose of LPCM on bluray to put on the disc the original sound that the directed intended without any "interuptions" from Dolby/DTS?
If Theatrical Audio Cuts were put onto LD with no problems and worked on people's mid range HT setups why isn't it today on bluray? I think it's safe to say that many HT's in today's homes are superior to many of the HT's in people's homes 20 years ago. So why couldn't the recievers, amps, 5.1/7.1 setups deal with it? -
I understand what you're saying. Again I want to confirm my suspicions, I'm not 100% confident this is always the case however; my understanding is that Laserdisc was the ultimate collectors format and quite honestly no....home theater systems 20 years ago were much better then today's average standard. There was no home theater in a box 20 years ago. Home theater to a great extent has been commoditized in the last ten years. When laserdisc was in it's height many Home Theater systems were large in nature usually in ones basement or dedicated screening room.
Having said that, there have been many advances and top flight electronics from today would crush stuff from yesteryear but as a mean average I believe HT was better 20 years ago. Compare the sound out of a simple Rear Projection TV from 20 years ago to today's ultra thin panel...no contest.
This video is interesting:
http://www.youtube.com/watch?v=dekW5sArpLg
My experience (from memory is the same). I'd love to have users try it and report back. Hopefully headrott can let us know his results. -
I saw several Deutsche Grammophon LaserDiscs at Salvation Army a few weeks ago. They were classical music of course and i assume they included the video track of the concertos. They were asking $5 apiece for them, but as i don't have a LaserDisc Player and i can't tell Brahms from Bach.... I just left them there for someone who could appreciate themYamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
I agree to an extent that "some" people back in the day had awesome theaters in their home but I think that would be a small % of the population and many people on this forum and others are pretty hardcore like with dedicated electronics for reciever, pre/pro, JVC/Pioneer projector and kuntasensei with his 10.2 surround system.
I personally have a 7.1 HT setup in my 27x27 room with over 9 foot ceilings over my garage.
My setup:
Pioneer Elite Pro-151fd plasma 60"
Pioneer Elite SC05 a/v
Sunfire Cinema Grand Signature 400 7.1 amp
Balanced Power Technology Signature Series 3.5 conditioner
Polk RTi A9 tower speakers L/R
Polk CSI A6 center
Polk FXI A6 sides L/R
Polk RTI A3 rears L/R
SVS PB12 Ultra sub
Is my system under powered with electronics and speakers to not get LD's potential in sound? -
I'd like to try that and see if I can find a Pioneer LD player to put in place of my Oppo bd player and do a back to back comparison, maybe a blind test and have some family members try to tell the difference. I still doubt a LD would beat a bluray LPCM like Disney's Pirates Of The Caribbean which Disney released on LPCM. -
Digital,
it wasn't a pissing match...simply put people had better home theater back in the day on average. Sure people like you have great HT's but many people consider home theater a system they can buy at wall mart. You couldn't buy HT in Walmart 20yrs ago. No different then most people had better stereo systems back 20-30yrs ago. I've been too two different partys this year. One couple had a Bose wave as their main stereo, another had a digital cable box playing music thru their plasma screen. That was their stereo system. -
Digital,
I wasn't trying to bait you or turn this into a back and forth contest. I was curious as to the sound between LD and BD is all and how my HT would sound with LD. -
I want one ....
You can never have too much E-Lectronix
http://cgi.ebay.com/PIONEER-CLD-1070-LaserDisc-LD-Player-Rem-20-Laser-Discs_W0QQitemZ400104944700QQcmdZViewItemQQptZUS_Laserdisc?hash=item5d281cf43c#ht_2222wt_1165Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
Headrott,
Did you have time to do the comparison yet? -
Headrott,
Sorry, I've been trying to find my AC-3 Demodulator as my newer denon reciever does not have an input. My older one did, but I sold it a few years back. There is one more container I need to check, but have to move some Monitor 10's and a few other things to reach it. Plus, I've been trying to get my new BAT VK-3i set up. Basically, I've been busy. I will see if I can do it soon though. Gotta find that demodulator though.
Greg
How big are these things.....laser disks were a bit before my time.HOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around -
Headrott,
Even compare the re-encoded two channel PCM tracks vs Blu Ray. It would be interesting.
Laserdisc's were the size of LP's but looked like a CD, they were pure analog stored in a digital medium, invented back in the 70's they lasted right up until 1999. The last laserdisc player made in Japan was in 2009 I believe as they were still supported in commercial applications. I believe the last Hollywood pressing was in and around 2000. -
OK, maybe I can try that. I am just so buisy it's hard to even get time to listen to my BAT VK-3i pre-amp I just got. I will see if I can compare the 2 channel PCM and True HD/DTS HD. I'll get back to you as soon as I can.
Greg
http://www.laserdiscvault.com/index.php?id=33&main_page=page
About LaserDisc Vault
OUR MISSION...
LaserDiscVault.com is dedicated solely to KEEPING LASERDISCS ALIVE!...by providing LaserDisc Collectors WorldWide the best selection of the highest quality Collectible LaserDiscs and LaserDisc related products.
WHAT WE OFFER...
LaserDiscVault.com offers New & Used Vintage LaserDiscs...specializing in "Hard-To-Find", rare titles from the silent era through 2000, specializing in titles not-on-dvd, horror, sci-fi, music concert, Walt Disney and cult classics, including all of your favorites from Elite Entertainment, Criterion, Roan Group, MGM/UA and others... Along with LaserDisc Movies, we offer a plethora of LaserDisc related items including; LaserDisc Supplies, Laser Disc Accessories, LD Memorabilia, Pioneer Elite LaserDisc Players, LD Operation Manuals and Service Manuals, LD Player Remote Controls, Professionally Matted & Framed LaserDisc Jackets and our very own LaserDisc Clock.
WHO WE ARE...
We are LaserDisc Specialists, focusing on...
- Titles that are unavailable on DVD or VHS.
- Titles that are available on VHS, but not on DVD.
- Titles that were released on DVD, but are now Out-Of-Print on DVD.
- Rare Titles that had only one version ever released on LaserDisc.
- The Best Version of a title that had multiple versions released on LaserDisc!
OUR HISTORY...
My Dad and I began collecting these awesome 12" silver platters called "LaserDiscs" once they were introduced into the marketplace. Yup...we were some of the crazy ones standing in line trying to grab some of those very first titles ever released! I remember sitting down with him and ordering our favorite titles from mail order places such as Ken Cranes and driving to "Record Town" to get some new titles for (his) collection. As his collection grew into the thousands, he would always let me take a few each week and watch them as long as I returned them to him in the same "Pristine Condition" that they left his house in. It was during this time that I fell in love with these damn things, although I didn't realize it at that time! I really grew to love the Artwork on the LaserDisc Jackets, and that is what continues to drive my passion for helping to keep this "LaserDisc" phenomenon alive and well forever! Dad was always one to jump on the bandwagon of a new product coming out...he always had the best Tube Amplifiers, Speakers and LaserDisc Players. So, it was no surprise when DVD's came out, he switched his attention to the little 5" discs and the LaserDiscs just sat there, and sat, and sat, until I was finally able to convince him to part with them! So, in early 2003 I successfully listed and sold my very first LaserDisc under the name of KM&M Enterprises, and soon after that LaserDisc Vault was born!...
...LaserDiscVault.com is dedicated to the memory of Jessica Marie Mitchell (October 18, 1971 - April 15, 2008)...My Best Friend & Matthew's Mommy!
LaserDiscVault.com (Est. 2007)
^^^ As I remember it, the Mcintosh players were essentially rebadged Pioneer Elites inside a different case. I could be wrong.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
That's incorrect, actually. The "studio mixes" you're referring to for the home are typically just re-equalized for near-field listening, which means a slight rolloff of highs similar to THX's default rolloff... and nothing more. The only other differences in the audio itself would be those inherent to lossy perceptual encoding (which is typically summation of audio that we don't necessarily perceive, which is what DD and DTS are both based on). Regardless, the dynamic range of the mix (or the mix itself) isn't altered when remixing a track for home use (barring a few exceptions where new mixes were done for DTS-specific releases on DVD - See Saving Private Ryan DTS edition for a perfect example.). It's essentially the equivalent of the RE-EQ feature on THX receivers, but done before the encode, which is why you typically see those "home mixes" on THX-branded DVDs. The problem with that where DVD is concerned is that people using their AVR's THX RE-EQ (or the Audyssey target curve on Audyssey-enabled AVRs) are essentially filtering the highs twice, because they were already filtered before the encode on those particular DVDs. That said, the vast majority of DVD soundtracks are NOT pre-compensated for near-field listening, and the ones that have been are typically labeled as such (i.e. "home theater mix" or "THX certified"). So if you had a laserdisc with an AC-3 track and a DVD, both encoded from the same master, laserdisc would have no advantage. If the DVD was compensated for home listening, the laserdisc would sound slightly brighter... but since the rolloff audibly starts to take effect near 12-14kHz, it's not going to be a massive difference, and given the different acoustic needs of large and small spaces, the DVD could very well sound superior.
To my knowledge, soundtracks on Blu-ray discs don't pre-compensate for near-field listening the way DVDs often did, so the theatrical mix is encoded directly. There's no need for DRC before the encode because both DTS and Dolby's variants of lossless encoding make allowances for DRC at the decoding level, using metadata in the bitstream to define the amount of compression. So long as you have DRC disabled in your AVR, you should be getting an identical recreation of the original theatrical mix, both in frequency reproduction and dynamics. That's the whole point of having the lossless codecs.
That's not to say that people who are going to be using TV speakers aren't accounted for where Blu-ray is concerned, since the base Dolby and DTS core tracks essentially have the same range as DVD tracks (though they're encoded at a higher, but still lossy, bitrate). Dolby and DTS handle this in different ways. Dolby has a base track (typically a 640k DD track) inside the bitstream for the TrueHD track, with the TrueHD data held separate from the base track. So if your system can only take the base DD track, that's what it sends out... If your system can play the TrueHD track, it sends that. DTS Master Audio encodes the DTS core/HD track, then has additional metadata above and beyond that which contains the additional data needed to restore the audio to master quality, which occurs when the core/HD track is summed with the additional metadata (which is partially why DTS-MA takes more processing power to decode than Dolby TrueHD). Two different ways of handling things, both of which losslessly recreate the original master.
As far as Laserdisc vs. DVD on a strict format level, AC-3 encoding is AC-3 encoding, and the differences will come down to bitrate. Demodulated AC-3 surround tracks on laserdisc were limited to 384k, whereas DVD tracks are encoded at 384k at minimum. DTS tracks on laserdisc, however, were full bitrate (1.5m/s) whereas DTS tracks on DVD are typically half bitrate (768k), with a few rare exceptions. And stereo PCM tracks on laserdisc were 16-bit/44k, which is CD-quality audio. Hardly comparable to what TrueHD or DTS-MA are capable of, especially over 20kHz.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Wow, that guy is so incorrect. DVD soundtracks aren't compressed in range the way he's thinking. Dolby Digital tracks contain separate metadata for dynamic range compression, but that only takes effect if you enable Late Night modes. Otherwise, you're getting the full dynamic range present in the original mix. It's actually superior to laserdisc because DVD can hold higher than 384k Dolby Digital tracks, with a full 115dB of dynamic range (105dB + the 10dB boost during decoding of the LFE channel).
One key to knowing he's full of crap is that he uses the term "Dolby PCM" in his responses. Another thing he fails to acknowledge is that stereo PCM tracks on laserdisc typically had 14-20dB of noise reduction applied because of the inherent weaknesses of the format, whereas the digital tracks on DVD don't require this. Also, he claims that DVDs scratch easier than CDs, which is ludicrous... because they use the same substrate. DVDs are more susceptible to scratches causing errors because there's more data in the same space as a CD, but neither is inherently more difficult to scratch. He also says Blu-rays are easier to scratch, which is just asinine, because of the protective coating they're given.
I could go on... but is there any point? This guy is someone who thinks they know what they're talking about, but who is essentially talking out of his **** in a vain effort to defend a dead format as superior. I hope he enjoys his collection of laserdiscs, but I'll gladly stick with DVD and Blu-ray.Equipment list:
Emotiva XPA-3 amp
Hi kuntasensei,
While I wouldn't take what the link says as gospel he does have a devoted website with a Hollywood Resume. I have no idea if it's legit however he at least has a name and some credits. Also, Dolby PCM is just a different way of saying Dolby Surround when referring to Laserdisc is it not? Dolby PCM is simply two channel sound re-encoded into 4 channel. I believe his reference to scratches was simply not how easily they could scratch, but rather how the scratches would interfere with the transmission of data.
I own a Blu Ray player and I don't own a Laserdisc player however saying that everybody that I've talked to and has compared for instance Mission Impossible audio LD vs DVD they mention it's no contest. Apocalypse Now is the same thing. DTS discs not even close however I realize that the increased resolution of LD over DVD in the DTS realm will play the major part. Saving Private Ryan, Jurassic Park are DTS examples often given. -
kuntasensei, Disney's bluray releases are LPCM audio "LPCM 5.1 (48kHz, 24-bit) with no Dolby or DTS. Wouldn't it be easier if all the studios did this and would it leave more space on the disc for other features like discs that have a lot of Java content?
DigitalVideo,
PCM takes up more space hence the need for lossless compression. -
Stereo PCM encoded with Dolby Pro-Logic is all good and well... but it's still CD-quality audio with matrixed surround data. That's fine for movies made before 1985... but since Batman Returns, it's irrelevant. Dolby Digital has a greater dynamic range than CD-quality audio (115dB compared to about 96dB theoretical range, though most CD audio only has about 75-80dB of dynamic range). There's no reason for DVDs to have compressed dynamic range because their digital tracks have the same dynamic range as the tracks in the theatrical presentation.
And as far as full bitrate DTS vs. half bitrate DTS, both are still subject to perceptual encoding and you'd be hard pressed to hear a vast difference between them. The primary difference would be that less of the frequencies would be summed, meaning the full bitrate track could have slightly more defined highs.
Still, compare that to a lossless track on Blu-ray and the entire argument of perceptual encoding and bitrate goes away, leaving only audio identical to the studio master. Comparing Laserdisc to DVD to Blu-ray would be basically the same, audio-wise, as comparing CD to HDCD to SACD/DVD-Audio.Equipment list:
Emotiva XPA-3 amp
Your comparison of LD to DVD goes against every real world experience I've encountered. DVD is a compressed lossy format end of story. LD PCM is not compressed end of story. I can agree about dynamic range but the word length is compressed. Have you done side by side comparisons? I ask simply because that's what this thread was entirely about since I created it.
