Is 150 watts RMS enough to push a Polk db1040?
GroverTheClover
GroverTheClover Posts: 1
edited February 2010 in Car Audio & Electronics
I'll be powering the db1040 with 150 RMS at 4 ohms in a sealed enclosure. The sub will be located in a hatchback so I'm not entirely concerned about volume per se, rather I'm curious as to see the quality of the sound with powering a sub 120 watts below it's max. Obviously I don't need to fully power it all the way up to 270 watts, but I'm focused on its effects on sound quality.
Post edited by GroverTheClover on
  • Jstas
    Jstas Posts: 14,974
    You should be just fine.
    Expert Moron Extraordinaire
  • MacLeod
    MacLeod Posts: 14,358
    Yup thatll work. If you can upgrade to a 300 watt amp later that would be better.
