about Polk R15 bookshelf speakers
Shadowmonic
hey i'v looked all over the web and i cant seem to figure out how to mount my R15 bookshelf speakers i ordered them and havnt received them yet but i want to order a inexpensive mount but i dont have enough information to know what kind of mount to get all it says is that theres a key hole slot in the back any help would be greatly appreciated
Post edited by Shadowmonic on
With a keyhole slot all you need is a screw in the wall, either into a stud or drywall anchor. Are you looking for more than that? Try this one-->
http://www.jr.com/pinpoint/pe/PPT_AM40/
Oh, and welcome to the club."Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." -
i want it to be able to rotate or be at an angle can i use this? http://www.a1components.com/itemdisplayn.aspx?item=11862
Shadowmonic wrote: »i want it to be able to rotate or be at an angle can i use this? http://www.a1components.com/itemdisplayn.aspx?item=11862
Not sure how those would work. Here's another option for you.
http://www.crutchfield.com/p_121BT33S/B-Tech-BT33-Silver-single-bracket.html?search=b+tech&ssi=0Things work out best for those who make the best of the way things work out.-John Wooden
