EVGA GeForce 8800GTX Superclocked 768MB PCI-E video card
DMara
Up for sale is a barely used EVGA GeForce 8800GTX Superclocked 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card (p/n: 768-P2-N835-AR), with retail box and PCI-E power connectors.
I got it from newegg (Read review here: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130079&cm_re=768-P2-N835-_-14-130-079-_-Product). It worked great, I only used it for a month or so before upgrading to a GTX 280. Therefore it has been sleeping in the closet for a while.
I will take $100 for it and will eat PayPal fee with free shipping. Either that or I will trade it for some AV power cable.
If you're a familiar CP member, I will send it to you first for you to inspect. Pay me if you're good with it. Don't like it? You can just send it back
That's how confident I am
Model
Brand EVGA
Model 768-P2-N835-AR
Interface
Interface PCI Express x16
Chipset
Chipset Manufacturer NVIDIA
GPU GeForce 8800 GTX
Core Clock 621MHz
Stream Processors 128
Memory
Effective Memory Clock 2000MHz (effective)
Memory Size 768MB
Memory Interface 384-bit
Memory Type GDDR3
3D API
DirectX DirectX 10
OpenGL OpenGL 2.0
Ports
DVI 2 x DVI
TV-Out HDTV / S-Video Out
General
RAMDAC 400 MHz
Max Resolution 2560 x 1600
RoHS Compliant Yes
SLI Support 3-Way SLI
Cooler With Fan
System Requirements
Minimum of a 450 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 28 Amps.)
Power Connector 2 x 6 Pin
Dual-Link DVI Supported Yes
HDCP Ready Yes
Features
Features NVIDIA unified architecture with GigaThread technology
NVIDIA Quantum Effects physics processing technology
Full Microsoft DirectX 10 Shader Model 4.0 support
NVIDIA PureVideo technology
NVIDIA nView multi-display technology
Model
Brand EVGA
Interface
Chipset
Core Clock 621MHz
Memory
Memory Size 768MB
Memory Type GDDR3
3D API
DirectX DirectX 10
OpenGL OpenGL 2.0
Ports
DVI 2 x DVI
General
RAMDAC 400 MHz
RoHS Compliant Yes
Cooler With Fan
System Requirements
HDCP Ready Yes
Features
Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000
Living room:
Bedroom:
Other rooms:
Post edited by DMara on
Sold on CL.Gears shared to both living room & bedroom:
Living room:
Bedroom:
Other rooms:
