First time theater setup. Help?
xaronax
xaronax Posts: 1
Hi! Blew most of my tax refund on speakers. Will be setting up my theater system Friday as soon as the UPS man arrives with my spool of wire. I know a decent amount about what I'm doing, but I have a few minor questions!
First, my setup;
2 x Monitor 70's for front L/R
CS2 Center
PSW505 Sub
2 x Monitor 40 Rear L/R
All connected to an Onkyo SR-607 AVR
Ok, questions;
1. My 70's can be bi-amped. With a powered sub, should I do this? If I do, what connection (LFE, inline wiring, pre-out?) and settings (on the AVR, SUB on/off?) should I use? Basically which is the best way to wire the fronts and the sub?
2. What does the phase switch (0 or 180) on the sub mean? I can't find a decent explanation except "try it and find out!" lol...
3. I will eventually buy another set of 40's for 7.1, and they will need to be on stands, does anyone have a nice pair that are cheap and effective?
4. I am intrigued by the DPL IIz, what speakers would you match with my setup for the L/R height channels? I'm assuming something lightweight and 2 way?
5. I haven't decided whether I want to run the wire for the rears through my attic or underneath the house. Input/suggestions/warnings?
6. Got a great deal on a spool of 12 gauge wire from monoprice. Will this be good for wiring everything?
7. Will girls go out with me now? ;)
Thank you very much if you made it this far. I really appreciate any help!
Post edited by xaronax on
  • packetjones
    packetjones Posts: 1,059
    edited February 2010
    Welcome to the club. Here are some short and sweet answers.
    1. Typically bi-amping with a receiver does not make a noticeable difference. Use the sub out on the receiver to the LFE in on the sub
    2. If the subwoofer is out of phase with the speaker system, bass frequencies will cancel each other. the switch will allow you to put the sub and speakers in phase. It is basically a try it and see if it makes a difference. It is based on the location of the sub more than anything else.
    3. I recently purchased some sanus stands from racksandstands.com. They have tons of options.
    4. No real comment on this. Look at the OWM series as there are tons of mounting options.
    5. no real comments on this either. I would do what ever is easiest. lol
    6. This is what I am using currently. There is a huge discussion about speaker wire and what is good/bad. Start with the monoprice wire and see what you think.
    7. With the new system wouldn't you rather they stay inside with you?
    Congrats on the new setup. Hope you enjoy it.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • kcoc321
    kcoc321 Posts: 1,788
    ^^ what he said plus
    #3. Research here about 7.1 before yo worry about it. there are numerous threads. Most concenses is that it doesn't really add much.
    #5. I would run them in the attic, since you will be mounting the rears closer to the ceiling than the floor. I would also rather climb thru an attic, rather than a crawlspace.,but that's just me.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    I am with the guys on this one. I agree with the advice given so far and will emphasize a few points. Before you jusmp into 7.1, make sure you will benifit from it. A properly setup 5.1 will outperform a cramped up 7.1 anyday. IMHO, the height/presence/width speakers (whatever you want to call them, lol) aren't all they are cracked up to be. If you want to try it though, the Monitor 30's are wall mountable out of the box and probably would do a good job. LFE is the way to go with the sub, connected via sub cable from the pre out on the back of your AVR to the 505's LFE IN. The speaker wire you got will do a good job, and I agree that Bi Wiring with an AVR isn't going to make much of a difference. The only drawback to that 607 is that it has no pre outs for adding an external amp, so if you ever wanted to send some real power to those 70's and amp would not be possible. Looks like you have a pretty good rig on the way (very similar to mine) and good luck with the setup. Welcome to Club Polk.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • harpdawg
    harpdawg Posts: 3
    Hello everyone, I'm new to the forum, my first post. I also just blew most of my tax refund on new HT system. I went from a 27" CRT TV connected to the old Sony stereo receiver (now powering the sub) to the 50" plasma & surround AVR. Wow, didn't know what I had been missing! I do have the height speakers connected & the 607 set to PLllz. Contrary to others opinions I've read here & on other forums, I do think they make a big difference. I watched "Gamer" (7.1 dts HD Master Audio) last night & this movie is a good one to showcase your HT! Bullets wizzed around the room at all angles. Helicopters sounded like they were directly overhead. I tried the same scenes on both the regular dts HD & the PLllz, and the height speaker do add some spacial & overhead positioning of things happening above you. The other night I turned on the end of "Reign of Fire" & in one scene the dragon growls from behind you then flies overhead (surrounds), then down in front (fronts), then pulls up over some building (front heights). At first I had the height mistakenly connected to the rear surround in the AVR, but now sound much better. After hearing what they can do, I'm now going to get 2 more & connected the rear surrounds; I'm thinking the AVR will choose either the rears or heights depending on the Onkyo 607 setting. Does anyone know if my thinking is right on this? By the way I'm bitstreaming from the PS3 & letting the Onkyo do the decoding; I like the cool lights on the reciever display instead of just always reading "All Ch PCM".
    My HT
    Panasonic Plasma TC-P50S1
    Onkyo TX-SR607
    PS3
    DirectTV HD Reciever
    Magnovox DVD Recorder
    Sony VCR
    Sony dual cassette
    Front R/L: Realistic 15" 3-way
    Center: Polk CS10
    Surrounds: Polk TSi4
    Front R/L Height: Polk T15
    Sub: Pioneer 12" TS-W3004SPL (sealed enclosure) powered by Sony receiver (60W @ 0.008% THD)
  • ViperZ
    ViperZ Posts: 2,046
    Just 1 comment: you have to decode in the PS3 and then PCM it out. PS3 cannot do a full bitstream over HDMI of DTS-HD MA and Dolby TrueHD, unless it's a new version PS3.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • harpdawg
    harpdawg Posts: 3
    Yep, mine is the new slim one; think mine is rev 2.85 FRMWR. Hit the display last night ("Gamer" BD) & sure enough the PS3 said 7.1 Dolby dts HD Master Audio bitstream & the display/LED's on the Onkyo said the same thing; that's until I switched it to PLllz, then that's what the display reads, but the dts HD & Master Audio LED's remain lit. The PS3 was defaulted to PCM, but once switched to bitstreaming it does. I could do it either way, I just like to see the LED's light up on the reciever. What's wierd is the Onkyo somehow knows what I have set for different channels on the Direct TV receiver as when switching channels it reverts to what was set the last time the channel was viewed??????
    My HT
    Onkyo TX-SR607
    PS3
    Sony VCR
    Sony dual cassette
    Center: Polk CS10
