car subwoofer help por favor
crizz99
crizz99 Posts: 2
edited February 2010 in Speakers
ok obviously im new to this forum, and youtube isnt effective enough to act as a chatroom for advice on subwoofers. Sometime this summer of 2010 i want to put a subwoofer in my car. Im willing to spend up to $400 on it about. I want a heavy heavy bass. But something ive noticed in my friends cars and stuff is that everything in the car also vibrates with the subwoofer and makes an annoying rattling sound. is there anyway to avoid this in my car without dimming down the bass?
Im very very new to this whole thing so if i went into bestbuy or something like that (idk where to go for it). what do i ask for? and the budget includes the amp and installation.
that brings up another point, is installing it hard? because my friend had his dad do it whos an electrician, and my other friend is wiring it himself. i dont wanna mess up on it but if its rlly easy then id love to not pay extra for it.
and sorry for asking this. im sure the forum is filled with questions like this
Post edited by crizz99 on
  • TNRabbit
    TNRabbit Posts: 2,168
    The only way to stop everything rattling is to tighten it all down. You'll rattle a car APART with "heavy heavy bass."
    I recommend JL Audio for a subwoofer. Great sound, great quality, great customer service. Go with a sealed box as big as you can fit & use a CLEAN amp. I'm using a Kenwood 1 channel sub amp on two Infinity Perfect 10.1 dual voice coil subs wired in parallel for a 1 ohm load. I'm hitting almost 1000 CLEAN watts into the two subs.
    Why run Infinity & recommend JL Audio? Infinity doesn't make the same Perfect 10.1 they used to. Efficiency is WAY down, & the low frequency response is up over 24 hz when the old one was 18 hz.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • crizz99
    crizz99 Posts: 2
    oh yeah another thing. just out of curiousity, are the subwoofers bolted down into the car? and is the amp bolted into the subwoofer? cuz they dont move around at all
