Driver Repair MW7202
Does anyone know if you can 'repair' a woofer? I have the RT800i's and one of the woofers has a defect... it looks like the rubber ring around the blue cone is coming separated for about 1-2 inches around the diameter. Looks like they are only glued in place on all the others. The speaker seems to function just fine, and honestly, I can't tell there's a problem. Only noticed it shortly after I bought these used - had the grilles off and noticed excessive vibration in that spot on the rubber ring with louder music. In nearly 5 years it has not gotten any worse, but I would like to fix it. Somebody mentioned gluing it with 'tack-tack' (spelling???) electronics glue.
Thoughts? Where can I get this 'tack-tack'?
Much appreciated!!
Much appreciated!!
Post edited by scubalab on
I have used these folks on vintage Yamaha speakers as well as recently on an M&K subwoofer repair. Very talented and reasonable......
http://www.empiricalsound.com/
Karl
