Preamp - Vintage or New
curved
curved Posts: 664
edited February 2010 in 2 Channel Audio
I've been trying to decide what I should pull the trigger on.
Oldest - Hafler DH-101, Dynaco PAT-4
Old - Yamaha C-60, Luxman C-02
Young - NAD Model 116
Newer - Parasound
It will most likely be paired with my Adcom 545.
HELP!!!!:confused:
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
Post edited by curved on
  • dorokusai
    dorokusai Posts: 25,576
    I like the Dynaco or Luxman choices.
  • george daniel
    george daniel Posts: 12,096
    I'll vote Dynaco
  • Hillbilly61
    Hillbilly61 Posts: 702
    Hope to hear more from the tube gurus/"whores" out there in Polkland!
    I am about to pull the trigger too. The OP question is very relevant to all that wants to do this.
    (Yes, I am pretty sure that I will become a tube "****", "guru" is an earned status").
    Guys, please weigh in here with your thoughts & experiences to us tube wannabes.
    Thanks,
    Lee
  • George Grand
    George Grand Posts: 12,258
    Hafler DH-110 instead of the 101. PAT-4 was not Dynaco's best effort. Luxman is very nice. APT "Holman" is very nice.
    heiney9 Posts: 25,418
    Hafler or Luxman
    Stay away from the Yamaha.
    Thanks,
    Lee
    ALL the pre's in this thread are SS so I'm not sure what your post is about.
    To the OP
    http://www.diyaudio.com/forums/analogue-source/54028-dynaco-pat-4-5-a.html
  • Hillbilly61
    heiney9 wrote: »
    To the OP
    Tubes as pre, SS as out.
    Hope this clarifies.
    Have no idea what your saying. SS as out.................out what :confused:
    The pre's listed by the OP are solid state units............no tubes. So I guess I don;t understand why you or the OP would get tube pre-amp recommendations is this thread.
  • Hillbilly61
    heiney9 wrote: »
    I'm mistaken. For a hybrid system, a tube input to a solid solid state input amp seems to be the way to go for some fine sound and an upgrade path. If the OP is interested in SS to SS then I am uninterested, as there are better sound to be had via alternatives
    Yeah, you lost me completely. Been in this hobby 25+ years and I have no idea what you're talking about.
    I think what you mean is a Tube pre-amp w/ a Solid State amplifier.
    Nothing in this thread has tubes in it, and the OP never mentioned tubes.......hence why I was initially confused about your post wanting to know about tube recommendations.
    A pre amplifier and an amplifier are two different things.
  • curved
    curved Posts: 664
    I appreciate all the quick feedback!! After talking with my wife, I think I'm going to step up a bit in $$ and make sure I REALLY like what I get.
    Pre - Nak CA-5
    BR - LG BD390
    curved wrote: »
    That's a good idea.
  • curved
    curved Posts: 664
    How do these stack up with the others mentioned?
    BRYSTON 1B PREAMPLIFIER
    B&K PRO-10MC Preamplifier
    Ideally, I would like to go with Conrad-Johnson PV10BL tube preamplifier, but I have to do some convincing....
    Pre - Nak CA-5
    BR - LG BD390
    curved wrote: »
    Both the Bryston and B&K are very nice. The B&K being one of the better budget units.
    The Adcom GFP 750 would be a better choice than both. The CJ and tubes would be very nice as well.
  • curved
    curved Posts: 664
    heiney9 wrote: »
    Would these be a big step up from the C-J Sonographe SC-25?
    Pre - Nak CA-5
    BR - LG BD390
  • TroyD
    TroyD Posts: 13,124
    Not really....
    BDT
