Upgrade speakers wires and sub cable?
bevo
bevo Posts: 306
I'm sure this type of thread has been done to death, but I've searched and couldn't find this question asked.
I have some 16g panasonic speaker wires I'm using that I got from walmart, and a rca sub cable I got from a second hand store. Is it worth upgrading my speaker wires, and sub cable? And if it is, what is the best bang for the buck wires and cable I can get. I don't have to go with the cheapest out there, but if they are as good as the more expensive ones, then cheap it is.
I'll be running wires 10 feet x3, 15 feet x2 and 30 feet x2. My sub would need about a 25-30 foot cable just to be safe in case I want to move it someday.
Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra)
Post edited by bevo on
  • thsmith
    thsmith Posts: 6,082
    edited February 2010
    You are right, cables have been done to death.
    I have Monoprice 14 gauge for my rears and center, happy with the results but for my mains I was not in 2 channel mode.
    AQ T4s or Kimber's equilivent would be good enough to know if your system is revealing and will benifit from better cables.
    I have a 20' Monoprice sub cable and have not felt the need to upgrade, but again I focused on 2 channel with my cables.
  • Hillbilly61
    Hillbilly61 Posts: 702
    Based upon just being around Club Polk for less than a year, this is a "dangerous" topic, as controversies easily erupt.
    Here's a link that might be useful to you:
    http://www.roger-russell.com/wire/wire.htm#wiretable
    While these are maximum wire length for the stated gauge, the ohms vary by sound frequency being delivered by the amp's delivered electrical current by as much as half of the nominal speaker impedance. Therefore, I use 1/2 the impedance to size my wires.
    Shielding, very common in "fancy" speaker wires, is very helpful if running in parallel to household electrical wires. The electric wires need not be visible. A speaker wire run under carpet less than foot away from a similar run from in wall or under floor electric wires will create interference if the parallel runs are long enough.
    Hope this helps!
  • dorokusai
    dorokusai Posts: 25,576
    I prefer www.signalcable.com for all my standard rigs and HT.
  • bevo
    bevo Posts: 306
    thsmith wrote: »
    I know it has been done to death, but all the threads I found were so random, and full of people bickering, that I hoped I might get some simple answers in here. So far, so good. I've also been in a bug upgrade mood for the last couple of weeks(income tax time), so I've made more threads in the last couple weeks, then in the year and a half that I've been a member here.
    In truth though, since I started these upgrades and tweaking my system sounds better then I ever thought it could.
    Are these the T4s your talking about http://www.audioadvisor.com/prodinfo.asp?number=AQT4NF&variation=10SBNSP
    They were so much cheaper at this place then anywhere else I wasn't sure.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
  • superjunior
    superjunior Posts: 1,632
    there's a nice set of mit t3's in the fm ;)
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • NotaSuv
    NotaSuv Posts: 3,871
    bevo wrote: »
    great start..nice price..let us know what you think.....
  • WilliamM2
    WilliamM2 Posts: 4,807
    bevo wrote: »
    There's no such thing as a wire upgrade. Just wire replacement.
  • dorokusai
    I like that phrase William.
  • Demiurge
    Demiurge Posts: 10,874
    I would suggest getting higher quality cables than the ones you have, but its my opinion you don't need to spend a great deal of money to get great sound. The law of diminishing returns comes into play. I like Signal Cable and really like Monoprice's (less expensive) stuff, too. Can't go wrong with either of those two and you won't break the bank.
  • cstmar01
    cstmar01 Posts: 4,424
    Demiurge wrote: »
    agreed. I'm using Signal and love it. Works wonderfully for HT and Frank is more than helpful when doing custom lengths and everything. Only a 10 buck charge for anything to be custom done for lengths ect. Some others but getting more expensive are the intro lines of MIT stuff such as EXP which work well I think but tend to cost a bit more. However Joe Abrams on Audiogon has the EXP1's ( I think) for a 12 ft pair for 128 bucks which is pretty close to cost of Signal (Ultra at that length) and I think they have the Iconn connectors which make things nice for switching between spades, bananas, ect without having to reterminate.
  • jinjuku
    jinjuku Posts: 1,523
    Your other alternative is if you have a Best Buy Magnolia location. The 30 day return policy will let you at least evaluate Monster and Audio Quest cables.
    Signal and Blue Jeans Cable have 30 day no hassle return policies. You would simply be out the shipping.
  • mshan242700
    mshan242700 Posts: 823
    Given speaker wire lengths, sounds like 14G would be appropriate.
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023902&p_id=2791&seq=1&format=2
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023902&p_id=2748&seq=1&format=2
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023601&p_id=621&seq=1&format=2 (probably would work fine as a sub cable)
    http://www.bluejeanscable.com/store/speaker/index.htm
    http://www.bluejeanscable.com/store/subwoofer/index.htm
    http://www.crutchfield.com/p_703142125/AudioQuest-FLX-14-2-14-Gauge-In-Wall-Speaker-Cable-125-feet.html?tp=1432 (I think you may be able to find spools cheaper if you google around)
    My top in wall wire for sound quality , actually I have 2 but Audioquest 14-2 is overall fantastic wire. In wall use and external use. Clear , detail , bass , mid's , highs all sound the way they are suppose to. I don't think this speaker wire adds or takes anything. I think it does it's job. Most of the time I feel there is no reason to buy anything else.
    Liberty also makes incredible in wall wire. They have a THX series thats as good as the Audioquest. You can argue it's just as good . They also have a 12g version that I would feel good using on any speakers made.
    Kimber Kwick series is another one of those cables that just perform. You can't go wrong with Kimber Kable for any wire need. Every single cable they make is top notch and can compete with anything made.
    If I had to choose a wire to use forever I might just stick with Audioquest or Kimber but if someone told me I had to choose Liberty I could live with that choice and never feel the need for anything else. When you achieve correct signal transfer , you don't need magic boxes or fancy braiding to make it better. There is no need to overspend on wire. I know this as I have over spent on wire all of my audio life. I learned the hard way and found companies that do it right for a great price. All 3 companies don't silly over charge you for what you get. Sure if you buy there highest offerings , you can question why you are doing so. Like Audioquest there entry level speaker wire isn't far off there top of the line. When you listen , you will learn that once you achieve the goal , your done. http://www.polkaudio.com/forums/showthread.php?t=90220
    http://www.sixmoons.com/audioreviews/whitelightning/moonshine.html
  • quadzilla
    quadzilla Posts: 1,543
    Bottom line in this is that it's what you can hear. Those that believe that cables don't make a difference don't hear a difference for whatever reason. Those that do believe that cables can make a difference, whether large or small, do hear a differance (and again, for whatever reason). I'm squarely on the side that cables can make a difference, and did hear a significant differance as I upgraded the cables and ICs in my system. But again, it comes down to what works for you.
    What I use is in my sig, and I'm quite happy with results I got for the money I spent. YMMV. If you know someone with some extra ICs and/or cables, see if they'll loan them to you so you can try them in your environment.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
