Adcom GTP-450
snow
Ok up for grabs is a starter Adcom Pre/tuner the GTP-450 with remote it is in decent not mint condition with a few scratches mainly on the top cover if it bothers you take the cover off grab a can of black spray paint your choice of flat gloss or semi gloss and go to town
I do not have the original box or owners manual.
$75.00 + SHIPPING money order preferred
REGARDS SNOW
REGARDS SNOW
Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Post edited by snow on
PM sent.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Finally!PM sent.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Damn... great price with remote.
Yes I am going to give polrbehr till 8:23 pm tommorow which would be 24 hrs to reply back as to whether he wants it or not, then it's back on the block.
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
For the record, I do want this.
Sent another PM to ya, snow.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
Got it. Consider this one sold folks.
Thanks for the sale Harry I custom made you a box for this preamp and it should arrive safely, I will mail tommorrow. Here is a pic of it packaged up.
Hmmm. Fra-geel-ayy? I thought it was an Adcom?
Thanks, snow. So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
Must be Italian."Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
