Intagrated amp with no pre outs would like to add amp
hogsfly
Ok might be stupid question hear!Is there any way of use my intagrated amp to run a amp that that have had for sometime and now would like to use.It has no pre outs :mad:or is there some other way to do it?
2 Channel System
POLk AUDIO SDA SRS 2.3
Proton D1200 amp
Proton P1100 preamp
Proton T440 tuner
Sony CDP-291
Sony CDP-591
Proton D1200 amp
Proton P1100 preamp
Proton T440 tuner
Sony CDP-291
Sony CDP-591
Post edited by hogsfly on
Well, hypothetically, yes, but there isn't a way to do it and make it sound good.
You'd have to get a step down transformer to hook up to the speaker terminals in your integrated, which would convert it to RCA, and a lower level signal, which would then feed the amp.
It can drastically change output impedance's, and really shouldn't even be considered as an option though.
Looks like it's time to invest in either a separate preamp, or a new integrated.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I tried one ages ago...sounded like crappola...Just get a preamp...you'll be better off.
Headphone out...Den
Parasound 2100
Parasound 2125
Denon DCM-390
LG BD390V
Martin Logan Preface(x2)
Denon AH-D2000
Bedroom
Adcom GTP-350
Parasound HCA-800II
Panasonic DVD-S54
Denon AH-2000
Polk S4(x4)
ಠ_ಠ
