Need SRT manual or install guide
dpowell
dpowell Posts: 3,081
edited February 2010 in Vintage Speakers
If all goes well, I will be bringing home a set of SRT's this weekend. I would like to get an electronic copy of the manual but can't locate it on the Polk website or anywhere on the web for that matter. Does anyone have those documents?
Many thanks to Ed (Esavinon) who has provided some very good guidance. I'd really like to 'see' the equipment and connection points on the back of the control unit before I head up to get these since right now, the seller has everything disconnected and I'll have to set it all up to test everything out. He had the system professionally installed when he bought it and doesn't know how to get it set back up. I'd like to have an idea of what to do rather than try to figure it all out on the spot and risk damage to the components.
Post edited by dpowell on
    nooshinjohn Posts: 26,002
    GOOD LUCK BRO!!!
    Remember, we need pics, in your home, or it didn't happen.
  • dpowell
    Absolutely!
  • schwarcw
    schwarcw Posts: 7,358
    Ed should be able to help you with those. I have heard Ed's SRTs. You are in for a treat!
    Carl
  • Bubinga99
    Bubinga99 Posts: 283
    I'm not familiar with these SRT's, and searching doesn't bring up much. Even the Polk vintage product page seems to no longer have live links. If you happen across an electronic copy of a manual, can you post it here?
    What do you do if you need one or more new drivers and/or replacements for the subwoofer/control electronics?
    What tweeter did they use in these?
  • ESavinon
    ESavinon Posts: 3,067
    Doug if you have a fax machine i can fax you the manual.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • dorokusai
    dorokusai Posts: 25,576
    Ed - Care to PDF it?
  • ESavinon
    schwarcw wrote: »
    You're overdue for a refresher carl.
  • ESavinon
    dorokusai wrote: »
    I'll think about it. It would take some time since i have alot of info on the SRT to convert.
  • dorokusai
    If you want to get it done for free, send it to me and I'll return it all with some extras. I have most of it I believe, just wondering what else I can get added to the archives or if I'm missing something....like that for example. I'm PDF'n a bunch of stuff now.
  • ESavinon
    I'll bring everything i have when i pick up the sub.
    Just make sure you wear your assless chaps and we'll be set.
  • ESavinon
  • dorokusai
    That's a deal Ed. What size shirt do you wear...XL?
  • ESavinon
    Yes sir.
  • dpowell
    ESavinon wrote: »
    Ed,
    Thanks! I can setup my fax machine to receive. I'll PM you my number. Just give me a call to set up a time that I can put the machine in receive mode.
    The link you provided is nice. Too bad the configuration link is broken...:( No worries, You've given me a good amount of info to work with.
  • dpowell
    "sunny" San Diego rained on my SRT parade today. :( Had to call the seller and postpone our transaction until Tuesday night. No way in the world I was going to risk bringing those home in the back of my truck with it raining on and off in San Diego a 60% chance of rain all the way between me and LA. Are they solid wood cabinets or particle board like the other SDA models?
  • ESavinon
    Mdf.
    Inquiring minds want to know where you stand on this.
    Hope you are still getting them.:cool:
