Pre-amp suggestions
wingzam
wingzam Posts: 201
edited February 2010 in 2 Channel Audio
I've got an Adcom GFA-5800 amp with SDA-1B's.I've switched between a Pioneer SA-9500II and a Sony STR DA90 ESG HT receiver as my pre-amps.
The Pioneer has a great array of adjustments,but doesn't sound as good as the Sony..after all these years I suppose it needs to be gone thru.
The Sony sounds excellent,but for a 2 channel system it's just overkill,and the Sound Field effects are no replacement for simple Bass and Treble knobs - and a far cry from the Pioneers dual Bass and Treble controls (a set up I prefer even to the SA-9800).
I need some suggestion for a pre-amp.
Initially i'm looking to spend a total of $250-300(including shipping),and as time goes by move up.
That said i'm thinking of having the pre-amp section of the Pioneer redone sometime in the future.Once this is accomplished how would this unit stack up against other pre-amps within its range?
Post edited by wingzam on
  • TNRabbit
    TNRabbit Posts: 2,168
    For simple, clean 2 channel on the cheap, the Carver C-1/C-11 is hard to beat. You can pick one up easily for well under $200.00.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • wingzam
    wingzam Posts: 201
    TN "no Polk audio equipment"?? For shame!
    Hey,what is the difference between the 1 and 11?
    There's 5 C-1's for sale on ebay right now!
  • TNRabbit
    Yeah, well...I sold my last Polk speakers in 1998....
    The C-11 is basically the C-1 with updated electronics & black/anthracite color.
    One note when you're looking; they are getting old now & may new service to bring them back to new specs so bid accordingly. Still an excellent pre. Being newer, the C-11 may be your better bargain right now as they are newer.
    TNRabbit
    Sunfire TG-IV
  • wingzam
    wingzam Posts: 201
    Will put that on my list!Thanks
    heiney9 Posts: 25,428
    Nakamichi CA5 or CA5II. Outstanding pre that you can pick up these days on the cheap. Also has an outstanding phono section if that's your bag.
    wingzam wrote: »
    I wouldn't bother if the only reason you're having it redone is to use a pre-amp. A newer dedicated pre-amp will be better. By all means get it redone if your going to use it as an integrated.
  • wingzam
    wingzam Posts: 201
    heiney9 wrote: »
    Nakamichi,they used names like "Dragon"!...oooohh I used to drool on their stuff back in 1980 at the base Sound Shop.Couldn't afford it back then - next on the list!
    "I wouldn't bother if the only reason you're having it redone is to use a pre-amp. A newer dedicated pre-amp will be better. By all means get it redone if your going to use it as an integrated."
    H9[/QUOTE]
    The only reason i'd do it was for the Bass and Treble dual controls,that was a great feature you just don't see anywhere.Plus that great Silver Face,but I agree with going the newer pre-amp.Heck about a month ago a 9500II went for $330 on ebay!Thats a ballpark I wouldn't mind throwing this one into...Will see...i'm kinda fond of the thing.
  • mguevarra61
    mguevarra61 Posts: 55
    Try the Parasound Model 2100 preamp. Maybe you can get a refurbished one for about $400.
  • bigred7078
    bigred7078 Posts: 477
    +1 but I think the refurbs go for like $450ish?
    You can find them used every now and then for $350-$375
    Pro-ject RM-9.1 w/ Grado Sonata 1 -> USP-1 -> RPA-1 -> Vienna Acoustics Mozart Grands
  • concealer404
    concealer404 Posts: 7,440
    Reposting over here:
    Check out this thread.
    http://www.polkaudio.com/forums/showthread.php?t=86866
    Please note that i ended up with a B&K Reference 5 SII. If you can find one of these, this is a VERY nice preamp. I love it.
    Another strange shot out of left field if you can live without a remote would be the Adcom SLC-505. It's a passive preamp that sounds great on some systems, and maybe not quite so great on others.
    I liked it as much as the B&K. Just as much. But for different reasons. But in the end, i wanted a remote, since my 2-channel is also currently doing TV/Movie duty. But that SLC-505 had an amazing soundstage and just sounded "right." Of course, being passive... it may have just been a matter of letting my source and amp play by themselves without interference. Who knows. :D
