Another "large or small"?
Hi guys, I am looking for some expert opinions
My set-up is as follows:
Center: CS10
L&R: T15 (I don't run rears)
Sub: Boston PV700
Receiver: Pioneer VSX-518
BluRay - Sony BDP-N460
My question is, I know the speakers are not towers or big by any means but they are bigger than satelite speakers, so should I set them as large or small?
The receiver offers small or large on the front and center (center can only be large if the fronts are) and the sub out has off, on, and plus... the plus is only available when the fronts are set to large. It sends more to the sub (like the front are set to small) so you still have full signal to the sub, plus the mid bass from the other speakers. I am sure that none of this is "news" to you guys, so what are your opinions? Is it bad to run them as large? The system is used for movies/tv and music... I appreciate any help you can offer. I don't want to set it up wrong and damage anything.
Center: CS10
Sub: Boston PV700
Post edited by jemrey81 on
Here's a good article that will get you started...http://forum.ecoustics.com/bbs/messages/34579/128214.html. A lot of good info but like all things audio related, nothing is set in stone. I like mine set to small at 70hz crossover. Dynamite sound! Play around & let your ears tell you what is the best setting."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
That's a great aticle, thanks for posting it. I guess I'll stick with small set to 80 (mine only has 50, 80, 120....
oops, my bad..... it has 50, 80, 100, 150, etc.
