Down Firing Sub Question on Carpet
Mr. Mojo
Mr. Mojo Posts: 53
I just ordered a PSWi 225 (down firing wireless sub).
My family room is fairly small, 15' x 12', and carpeted.
Is it worth the time to cut out a small 13" x 13" piece of plywood to sit the subwoofer on to increase bass rather than just have it sitting directly on the carpet?
Thanks for any help.
Post edited by Mr. Mojo on
  • concealer404
    concealer404 Posts: 7,440
    edited February 2010
    I would say yes....
  • mhmacw
    mhmacw Posts: 832
    i would suggest 3/4 medite if you can or even a piece of tile from a flooring store .they generally have a left over from a job lying around.
  • Knucklehead
    Knucklehead Posts: 3,602
    I have a 10" down firing sub that I use for XBOX play, my house has a crawl space so I purchased a decorative brick paver from home depot for $5, works perfect.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • grimmace19
    grimmace19 Posts: 1,429
    I just finished a project where I took a 3cm thick slab of granite (free from a buddy who works at a granite shop) and used silicone to attach cabinet feet to the bottom. Got a slight increase in sound quality but a huge decrease in vibrations in the room. If you can, the heavier the sheet underneath the better.
  • Huck344
    Huck344 Posts: 453
  • halo71
    halo71 Posts: 4,632
    grimmace19 wrote: »
    This has me wondering about doing something similiar. I have a piece of black marble left over from when I had my kitchen cabinet tops installed. Its about 16"x16" and, I think, 1 1/2" thick. Think I am gonna sit my sub on top of it and see if there is a difference. It's sitting on carpeted floor right now.
    --Gary--
  • Mr. Mojo
    Mr. Mojo Posts: 53
    halo71 wrote: »
    Let us know!
  • thsmith
    thsmith Posts: 6,082
    Subdude works very well. I have used it on hardwood.
  • grimmace19
    The marble would work perfect. I originally didn't even put the feet underneath the granite and had good results. However, the feet actually helped a lot. Parts express sells them very cheap... I think I picked up 8 of them (2 subs and 2 sheets of granite) for around 70 cents each. Well worth it and because the slabs are so heavy the feet sink deep into the carpet so you can't even tell they are underneath.
  • Uilleann
    Uilleann Posts: 159
    I don't mean to sound off out of turn - but why not simply purchase a front firing sub to begin with? To my mind - this may solve many of the concerns you have about firing directly into a carpeted surface. I stand ready to be corrected of course. ;)
    Best of luck!
    Brian~
    AVR: Denon X3200W
    Mains: Polk TSx440T
    Center: Polk CS10
    Surround: Polk TSi300
    Sub: Polk PSW110
    Video: LG OLED65B6P Panel
    BDP: Sony BDP-S6500 Blu-ray player
  • packetjones
    packetjones Posts: 1,059
    i have a peice of glass under mine. It is basically a glass cutting board i picked up for about $2. It made a significant improvement since i have thick carpet. It is worth a try to put something under it and see if it makes a difference.
    I think that the subdude is mainly to reduce vibrations. i am sure it makes an audible difference as well but mainly to decouple form the floor.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • concealer404
    Uilleann wrote: »
    Best of luck!
    Brian~
    I think there was just a thread on this... give me a minute, and i'll update this post with the link.
    Here ya go! :)
    http://www.polkaudio.com/forums/showthread.php?t=93988&highlight=downward
  • grimmace19
    I haven't tried a sub-dude but one bad thing about it is that the normal size is too small for my woofer. Because of this, I was able to seek out the DIY option and save a ton of cash in the meantime.
  • Uilleann
    Uilleann Posts: 159
    In re-reading the original post, I'm wondering: are you only concerned with "increasing the bass"? If so, turning up the gain on the sub, increasing the line level output on your AVR to your amp or sub (if self amplified), or purchasing a second sub would all be viable options I would venture to guess. If you're wanting to alter the tone of the sub, that's where I woul think a front firing enclosure might serve you well.
    Typical bass response in music, if played on a system that has a truly flat frequency response, is surprisingly softer than many of us realize. It is different than what you hear in clubs, at live concerts - and certainly far different from your average movie theater these days. Do you know how accurate your system's response is presently across the spectrum? You may be more accurate than you think!
    Of course, your own ear is the final judge, and we all have our own feelings at the end of the day about what *sounds* best to us. I would suggest thinking about the kind of bass you're really looking for - if its simply sheer volume, its easy to do. Though I would think that more watts, a bigger driver, or multiple drivers would afford you much greater control than simply the question of carpet vs. hard surface.
    Happily learning along with you here of course... :)
    Brian
    AVR: Denon X3200W
    Mains: Polk TSx440T
    Center: Polk CS10
    Sub: Polk PSW110
  • Huck344
    Huck344 Posts: 453
    thsmith wrote: »
    That's what I need mine for. Hardwood in the new house is sending tremendous amounts of vibration. I'll have to check it out further.
  • Mr. Mojo
    Mr. Mojo Posts: 53
    To answer a couple questions here:
    I'm buying the downfiring because it is wireless and will fit out of the way and will complement my other front firing subwoofer. The Polk PSWi225 has received good reviews and is inexpensive so I want to give it a try.
    The reason I'm asking about adding a small platform to put it on is I thought it might have better performance if it was not sitting directly on the carpet which sould absorb some of the bass.
    I really appreciate all the input here.
  • Derrick4Real
    Derrick4Real Posts: 46
    Was thinking about getting this myself. I live on floor 2 of a 2 floor apartment (all hardwood floors too).
    The consensus, from what I have read on the larger forums (AVS), is that its overpriced for what it does.
    $60 for a velour covered unit...$50 for the regular one. Im digging it myself...
    Heres another link for it: http://www.truesoundcontrol.com/products/SUBDHD.html
    Receiver: Onkyo TX-SR607 7.2
    TV: Samsung Q70C 55" 2023
    Remote: Logitech Harmony One
    Blu-Ray: Sony NSZ-GT1 with Google TV
    Streaming: Chromecast w Google TV 4K
    Fronts: Polk Monitor 70
    Center: Polk CS2
    Sub: Polk PSWi225
    Rears: Polk Monitor 40
  • howardru
    howardru Posts: 26
    I just put all my components together over the last month and have been tuning all the components. My HT sits in a corner and I have little options for sub placement and have it behind the main component TV stand between the two VM30s. The Pro 600 has a remote for multple settings and I had it for set for Corner with 0 phase.
    I was not about to move the sub to my typical seating position and crawl around on the floor listening to bassy-tunes to find out where the best place for the sub would be...because the ONLY place was behind the TV, in the corner.
    So I downloaded that Bink Audio Test CD (See my post from yesterday) and ran the sub at varius Hz settings and walked around the room. I noticed that at 50Hz, the sub pretty much disappeared from my typical seating position. This was the only frequency that I had this much of a drastic sound problem. So I looked at these sub "elevators" and saw that the only one that would fit my Pro 600 was $80+. I said...to hell with that.
    Well I took a ride over to Home Depot and picked up 3/4 inch MDF board and cut an 18" square. Painted it black and used some Gorilla brand Duct Tape to completely cover 3 standard bricks (for color match) and threw it all together. (Don't know why but 4 bricks made it unstable...go figure)
    The lifting of the sub off the floor 3 inches and now projectin into the MDF board (instead of corner carpet) has restored the 50Hz bass back to my optimal seating position. Total cost for the board was $9 and I needed 1 more brick for 33 cents!
    Who need to pay outrageously for such a simple solution?
    AUDIO
    Receiver - Onkyo TX-NR709
    Main L/R - Polk VM30 (Hi WAF)
    Center - Polk VM20
    Surr L/R Side Yamaha Inwall
    Surr L/R Rear - Yamaha NS-IW660 InWall
    Height: Dolby Prologic IIZ - Bose 161
    Sub- Polk DSW Pro 600
    VIDEO
    T.V.- 55" Samsung LED UN55B8000 240Hz
    Tivo HD w/1TB External Storage
    Blue-Ray- Playstation 3 Slim - 250GB
    Gaming - PS3 & Nintendo Wii
    Power - Panamax M5300-PM
    CONNECTIVITY
    Network - 8 Port GbE@ 3 x 802.11abg APs
  • Huck344
    Huck344 Posts: 453
    thsmith wrote: »
    Thanks for this recommendation. I bought the Subdude and got it late last week. As soon as I placed it under the sub, there was an immediate difference. Bass is much more tighter and nothing rattles. I would definitely recommend it for those with hard wood. Is it overpriced? Probably, but it did exactly what it was supposed to do.
  • Rivrrat
    Rivrrat Posts: 2,101
    I have saltillo tile floors over a concrete slab, and I found the sound off the tiles to be too "boomy". I ended up putting a terrycloth dish towel under my sub to tighten up the sound.
    My equipment sig felt inadequate and deleted itself.
  • shadowofnight
    shadowofnight Posts: 2,735
    I had some laminated 2 inch maple bases made for my downfiring 15's....drilled small holes for the spikes...solid as a rock...no shifting.
    The first rule of Fight Club is you don't talk about Fight Club
  • Sherardp
    Sherardp Posts: 8,038
    Looks very nice bro. What subs you using Shadow?
  • howardru
    howardru Posts: 26
    ShadowofNight,
    Nicely done. Great solid base to reflect back up the sound.
    They must really heat up the room..especially in front of that fireplace :-)
    Wife must love em!
    AUDIO
    Center - Polk VM20
    VIDEO
    CONNECTIVITY
  • DMara
    DMara Posts: 1,434
    edited January 2011
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • crazytasty
    crazytasty Posts: 18
    edited February 2011
    awesome subwoofers! What is the brand?
