Also need a pair of SL6506 tweeters
kcoc321
I am also in the market for a pair of SL6506 tweeters for my RT55i restoration project. Please PM me if you have them and how much you want.
:rolleyes: :eek:
I am in Edmonds, WA 98026.
KC
KC
Post edited by kcoc321 on
Bump
Please
Are these things that scarce?
I 'could' also go for some MW6511 even, as those are what is/ was in the RT55 standards. -
bumpitty
Okay, IF none has any MW6506's of MW6511's,
does anyone know which of the smaller RTi's these came in?
Maybe I can find some for cheap..... -
Saturday nite BUMP
I've got two (2) SL6506 tweeters on order for my RT2000P speakers. Are there resistors that need to be wired in or do I connect them directly to the black and red wires comming in. I bought these without tweeters so I'm sure what they looked like before they were disassembled.
Thanks -
Hi Randy, Welcome. You are much better off starting your own thread with your question. Polk CS should be able to help you as well, if they are the ones that recommended that tweeter to you. If it is a direct replacement, then you should be able to connect it to your crossovers, which already are designed with the resistors and capacitors required. -
dbl post
Friday bump...someday
