8 ohm load to 4 ohm driver.
mhmacw
mhmacw Posts: 832
edited February 2010 in 2 Channel Audio
what really happens when you deliver an 8 ohm signal to a 4 ohm driver?
Post edited by mhmacw on
  • concealer404
    concealer404 Posts: 7,440
    Nothing, because that's not how that works.
  • steveinaz
    steveinaz Posts: 19,545
    "8 ohms" refers to how much resistance is present, it's not a signal. Are you asking what happens when you drive a 4 ohm speaker with an 8 ohm specified amp?
  • mhmacw
    mhmacw Posts: 832
    well i have a low impedance switch on my amp and i know the voice coils are 4 ohm. i wonder what happens when i run 4 ohm coils on "high "impedance setting or 8 ohm. ive run other speakers that are rated 8 ohm on the low setting but they werent dual coils. i just didnt want to fry anything. it seems to me the sound is more defined on high impedance.
  • mhmacw
    mhmacw Posts: 832
    not how what works? ive gone lower on speakers but not higher. lol what going to smoke first?
  • steveinaz
    Set your amp switch to the "nominal" impedance of your speakers. Look at your speaks spec sheets to get the nominal (aka "average") impedance. When in doubt, go with the lower 4 ohm setting (amp) to protect the amp against too much current draw, in case your speakers happen to be 4 ohm.
  • mhmacw
    mhmacw Posts: 832
    steveinaz wrote: »
    it is dual voice coil so it could be 2,4 or 8. right now i have a channel to each coil at low impedance(4 ohm). but it tightens up and sounds much more crisp when i switch to 8 ohm. is it going to explode?lol should i order a new one right now?
  • concealer404
    mhmacw wrote: »
    Either way, your amp will attempt to drive a 4ohm load, because that's what you're presenting to it. You don't have control over that as long as you run that driver.
    It's up to you to decide/find out if your amp is up to the task.
  • steveinaz
    mhmacw wrote: »
    An amp set to drive 8 ohm speakers may overheat/shut down trying to drive a 4 ohm load, due to too much current.
  • steveinaz
    mhmacw wrote: »
    What speaker are you driving?
  • mhmacw
    mhmacw Posts: 832
    steveinaz wrote: »
    its my subwoofer. im waiting on my plate amp so im using another old receiver for the next week or so
  • mhmacw
    mhmacw Posts: 832
    so should it be switched to 4 ohm(i checked the manual its 4 and 8 ohm) or will it do it anyway?
  • concealer404
    mhmacw wrote: »
    It'll do it anyways. It doesn't matter what you set the reciever to, it'll still see the same load from the driver, so it'll do whatever is necessary by the driver.
    Switching to 4ohm probably just trips some kind of limiter to prevent overheating. It shouldn't change how the power is sent or created.
  • steveinaz
    To be on the safe side, keep it at 4ohms--unless you can find out definitively what the nominal impedance is of the sub.
    Here's the deal; less impedance requires a more robust amplifier (I know, it seems counter-intuitive). When resistance (impedance) drops, current rises---too much current and the amplifier section of the receiver will overheat/shutdown. An 8 ohm load is easier to drive because there is not as much current demand on the amplifier section. This is why your better amplifiers are "high current" designs that will safely drive lower impedances---giving you more flexibility in speaker choice.
  • mhmacw
    mhmacw Posts: 832
    they are 4 ohm coils i know that much lol...its rocking the house with 100(supposed) watts im a little scared to see what itll do to the windows with the 500 watt 8 ohm amp. it sounds good too i just didnt want to break it befoer its broke in thats all.
  • steveinaz
    How are you running it without the plate amp? Tell me you're not connected directly to the bass driver, right? Although you'll probably smoke the receiver long before the driver....LOL
  • mhmacw
    mhmacw Posts: 832
    steveinaz wrote: »
    LOL I wondered how long that would take to get this question haha. no im not connected un filtered to the source. i went sub out from my main receiver to a y splitter to the phono in on the old receiver. they both have a 47K ohm impedance rating.
  • steveinaz
    WHAT? Unhook that crap man. Sub-out to phono-in? Are you serious? Why would you run from one receiver to another using the sub-out and phono in? What's that suppose to accomplish---other than god-awful sound?
    Damn Funkenbush, wait for the plate amp to come.
  • mhmacw
    mhmacw Posts: 832
    steveinaz wrote: »
    yea why not?
  • steveinaz
    NO...more like "WHY?"
    You have a sub output (line level signal) going into a phono input (preamplified, NOT a line level input) that is not designed in any way, shape or form to handle a sub signal.
    It's like connecting my motorcycle alternator to my cars AC and asking why my left speaker doesn't work...ROTFLMAO!!!
    The really funny things is....you're concerned about which position to put the receivers impedance matching circuit switch to, you're killin me man. That's like buying an airplane because you like free peanuts.
  • mhmacw
    mhmacw Posts: 832
    steveinaz wrote: »
    whats the problem? its not like im blasting any thing and it gives me a chance to tune the box ports. sure the headroom is like crawling under a car but. just turn it all down and at least you can tune **** at least the mechanical tuning part. funkenbush ...that s funny. the impedancese are the same .sooo electronicaly it isnt goin to hurt anything. just the presence of that sub is plenty believe me. yea its not "preffered" but hell its just a dx -940 any way if it blows it blows. however.... "polk guru" i will go unplug it and wait for the amp....&#$*!$&^ i hate mentors sometimes lol
  • steveinaz
    You are a crazy man, and I dig that about you baby! LOL!!! Classic!
  • mhmacw
    mhmacw Posts: 832
    steveinaz wrote: »
    if i keep it between the fences do i really have to unplug it?
  • dudeinaroom
    dudeinaroom Posts: 3,609
    Take it off the phono in, and run it into a tape,cd, or an aux in. dx- 940? Or is it a SA-DX940?
  • TNRabbit
    TNRabbit Posts: 2,168
    Do anything you want; it's obvious you're going to anyway. Just don't come crying to us when you destroy your system~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • mhmacw
    mhmacw Posts: 832
    i thought of that but the impednace is wrong. 22k for the cd and 47k for the phono. its an sasdx940. an old technics piece of **** that was lying around so ...se la vie if it does go.
  • mhmacw
    mhmacw Posts: 832
    TNRabbit wrote: »
    lol cry? i wouldnt hold my breath if i were you! go buy another...or 10 more if i so desire... likely. as for doing anything i want TCH!!! why the hell do you think i asked? it is unpluggeed , i am waiting for the plate amp and i did take steves advice so i guess you missed that one too eh?
  • mhmacw
    mhmacw Posts: 832
    mhmacw wrote: »
    guess i should have put one of those sarcastic faces behind this post so those with out a sence of humor wouldnt have been confused :confused:
  • unc2701
    unc2701 Posts: 3,587
    1) The phono input expects no more than about 10mv; the sub output can put out up to around 2000mv
    2) There's a reverse RIAA on the phono input. This boosts the bass and drops the treble. If what you're listening to has any subsonics it's possible that it'll melt your voice coil.
    So, move to a CD or tape input, set the switch to 4ohm and sit tight until the plate amp arrives.
    Backburner:Krell KAV-300i
  • mhmacw
    mhmacw Posts: 832
    unc2701 wrote: »
    hey thanks man. the specs said 37 mv for the sub out so i figured it wasnt too bad. i took it down so no worries but thanks for the info.
  • unc2701
    OK, the input sensitivity on your phono input is 0.4mv, so you will overload it- what's your AVR for the sub out? 37mv seems like a weird spec for that.
