TT Mats
Toolfan66
Toolfan66 Posts: 18,031
edited February 2010 in 2 Channel Audio
I want to upgrade my mat, looking for feedback, and best place to buy.
I would also like to get a steamer to clean my vinyl with as well.
Thanks,
Larry.
Post edited by Toolfan66 on
  • ben62670
    ben62670 Posts: 15,969
    Try Herbies. I haven't done it yet, but Polkies seem to like them.
    Ben
    BTW I don't know if I spelt Heries correct.
    Ben
    I was just looking at their site, I would think the Way Excellent II-3.7mm would work just fine. But is a carbon fiber mat better then rubber?
  • hearingimpared
    hearingimpared Posts: 21,136
    Larry,
    Both the Herbie's mat and carbon fiber mats are very good choices and the suggestion put forth by Mike about getting a good reflex clamp is a must. If you buy the Clearaudio Twister Clamp, you being a machinist I would make three different thickness delrin shims to place under the record. For more details on the shims, PM me.
    http://herbiesaudiolab.net/ttmat.htm
    http://www.google.com/search?q=+carbon+fiber+record+mat&rls=com.microsoft:en-us&ie=UTF-8&oe=UTF-8&startIndex=&startPage=1
    http://store.acousticsounds.com/d/36249/Clearaudio-Twister_Clamp-Record_Mats_and_Clamps
    http://www.needledoctor.com/Clearaudio-Twister?sc=2&category=421
    http://www.audioadvisor.com/prodinfo.asp?number=CLTWICL
    Be very careful when purchasing a steamer. Make absolutely sure it is not a refurb. I made the mistake of not checking to see if the one I purchased was a refub and it is a disaster. It spits water all over the place and now I can't even get the top off of it. It is now an ugly paperweight.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Larry,
    How are you liking the SL1210/DL160 combo? The vinyl bug has been biting me pretty hard lately, so I'm starting to look at new TT's. The 1210/160 combo is one of the options I've been considering.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    Keiko wrote: »
    Larry, I'm using the Herbie's Way Excellent mat on my 1210 and have been super pleased with it. Combine it with a good reflex clamp and enjoy.
    Mike,
    Is this the one you got? (Way Excellent II-3.7mm) it's the one I am looking at.
    Thanks.
    Larry,
    Thanks for the links, I will PM you on the shims. do I really need the steamer if I get the VPI 16.5?
    Larry,
    I love it!!! I would say about all 75% of music I buy is on Vinyl, used and new. It took a little time getting the Jolida JD-9 phono pre tweeked in, rolliing tubes adjusting the switches to the DL-160, but it's all magic now.
    My advice is be patient when getting into vinyl the payoff is fantastic, to me it's like fine tuning a car but thats what makes it a hobby right?
    Larry.
  • hearingimpared
    Everyone I know who owns one loves it and would probably say yes. I don't use it anymore and have found my four step prep process used once on each LP then just a spin with VPI cleaning fluid before each play does a fine job. I get pristene records after I do it.
  • Dawgfish
    Dawgfish Posts: 2,554
    I am another member who is running a SL-1200 MK2/DL-160 combo and absolutely love it! I picked up my SL-1200 for $150 used. I've also added an LP Gear billet aluminum headshell with the LP gear gold headshell lead wires, KAB USA's new record clamp for the SL-1200, Herbies Way Excellent 3.7mm mat, KAB USA isolation dome isolation feet, the phono cable from the SL-1200MK5 (gold plated RCA plugs instead of the standard MK2's nickle plated RCA Plugs), and KAB USA's tonearm fluid dampener for the 1200. I am using a Parasound P/FET 900 as my phono pre. I have about $700 to $800 tied up in everything mentioned above.
    I couldn't be happier with the setup. It sounds awesome! I've heard turntable set-ups that cost 4 to 5 times or more than mine and IMHO, I'm not giving anything up to the more expensive setups other than prestiege and wow factor. In the future I am going to add a Jolida JD-9 phono pre, a Grado Reference Platinum Cartridge, and one of KAB USAs slip-on cherry wood bases for the 1200 and I'll be done with it.
    I kind of got off topic here. The Herbies Way Excellent 3.7 mm (285mm diameter) mat works great on my 1200. I couldn't be happier!
    Steve
