Dolby TrueHD + DTS-HD vs Dolby Digital + DTS
Dan2036
Is their any audible difference between the two formats ? Compressed vs Uncompressed and Dolby vs DTS ?
TV- Samsung 24" LCD T240HD
5.1 Receiver - Harman/Kardon AVR 247
Stereo Receiver - Harman/Kardon 3390
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD
Playstation 3
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD
Playstation 3
Post edited by Dan2036 on
Dolby vs. DTS- yeah
compressed vs. uncompressed- yeah
Dolby True HD vs. DTS-HD- not so muchHT basement room:
TV- 42in Panasonic S1 Plasma
A/V Receiver- Onkyo NR807
Blu-Ray- 80GB Sony PS3
Power Supply- Monster HTS-1600
5 Disc Sony CD/DVD Changer
Time Warner HD Cable Box
Speakers:
Front- Polk RTi A3
Center- Polk CSi3
Side Surround- Polk RTi4
Back Surround- Polk RM6750
Sub- Outlaw Audio LFM-1 EX
Bedroom:
32in Visio LCD, Sony STR-DE685 AVR, MTX Monitor 12, Sony 5 disc DVD changer -
Which ones are better (in your opinions) as far as DTS vs Dolby ? How big is the difference between compressed and uncompressed ?TV- Samsung 24" LCD T240HD
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD
Playstation 3 -
Uncompressed, there is no difference between Dolby True HD and DTS-HD. They are just two methods to compress the same file, and give the same uncompressed lossless results.
For a regular DVD, which uses lossy compression, I prefered DTS over Dolby. It just seems a bit better, but few DVDs offer DTS.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
for regular dolby digital and dts, dts seems better for most movies. The DTS format is said to use less compression than dolby so it is a little more engaging. The uncompressed formats are pretty much the same because they are "lossless" meaning they are exactly the same as when the movie was made for theaters, nothing is lost or compressed. Its a pretty big difference between compressed formats and non-compressed.HT basement room:
Speakers:
Front- Polk RTi A3
Center- Polk CSi3
Bedroom:
Good to know thanks for the help guysTV- Samsung 24" LCD T240HD
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD
Playstation 3 -
Dan i was looking at your equipment in your sig and see you use ps3. If you haven't used the lossless audio formats with it yet and are going to, you need to make sure your audio settings on PS3 are set to Linear PCM through HDMI to get the lossless formats... unless you have the new slim ps3.HT basement room:
Speakers:
Front- Polk RTi A3
Center- Polk CSi3
Bedroom:
keeneyrm01 wrote: »Dan i was looking at your equipment in your sig and see you use ps3. If you haven't used the lossless audio formats with it yet and are going to, you need to make sure your audio settings on PS3 are set to Linear PCM through HDMI to get the lossless formats... unless you have the new slim ps3.
+1, the older PS3's won't bitstream, only pass the signal via LPCM. I have heard both the newer codecs and I honestly don't have a preference for one or the other, they both sound amazing.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Ya thanks took me awhile to figure that one out but i think i finally have it working, Tried it out today and i really feel that the system see's a huge boost in bass frequencies, way fuller soundTV- Samsung 24" LCD T240HD
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD
Playstation 3 -
Yeah i was missing out on the lossless formats too when i first hooked mine up cause it was set to bitstream but what a difference it makes when its set up right and getting the HD formats.HT basement room:
Speakers:
Front- Polk RTi A3
Center- Polk CSi3
Bedroom:
With LPCM, you won't get the display to show "Dolby TrueHD" or "DTS HDMA" but all you have to do is press the select button on the PS3 controller and on the top right of the screen it will tell you what format it is playing in.
-JeffHT Rig
Blu-Ray- 80 GB PS3
I have a Pioneer Elite Pro-111fd and Pro-15fd plasma and they have the option in the Sound Setup to set it to Dolby or PCM on the tv. Does that make a difference when watching HD cable tv through HDMI?
