Need help with in/ wall speakers
I think I'm going to use monitor 60's for my fronts. The center will be a cs2. Now for the Question what in/wall polks for the rear? Does polk make a in/wall speaker that will match the monitor speakers? Thanks for the help.
Post edited by vols9898 on
This is going to be in a media room. Mostly movies very little music.
This forum is no help at all. I thought this would be a good place to find out information on polks.
Most people don't need a perfect match for rears. I think any of the MC series in-walls should do. I don't think many people run in-walls here in this forum. Best way to be sure is to call Polk directly.
Fronts: Energy RC-70
Center: Energy RC-LCR
Surrounds: Energy Veritas 1.0CM
Subwoofer: SVS PC12-NSD
Receiver: Onkyo TX-SR705
Amplifier: Denon POA-2200 w/ Ben's ICs
Pics of my setup (click me) -
I would call CS and ask, but theTCi625i looks like the match for your speakers.
http://www.polkaudio.com/customaudio/tci/index.php?s=tc625iDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Hm, it says those match the RTi A's, which sound quite different from the Monitors...
I've been wrong beforeDodd - Battery Preamp
The in-wall match for the monitors is the RC series (55,65, or 85). Size them based on your room size and seating distance.
You can find a pair of the RC65i on Amazon for about $150. Good luck.
