Help wiring Atrium 60
PSOVLSK
Just got a pair of Atrium 60,s and I'd like opinions on wiring them. I have a "rock" speaker that I got from Tweeter, so I use it on one channel. For the other channel, should I A) only use one of the Atriums or
use both of them. If I use both Atriums, how would you recommend wiring them?
FYI: I previously had a cheap pair of outdoor speakers that I ran together with the "rock" speaker and they worked fine. I had them wired in series.
Thanks.
Thanks.
Post edited by PSOVLSK on
Unless the "rock" speaker is better than the 60s (doubt it), I would connect both 60s. I would connect one to the right and one to the left. You run into problems when you start connecting in series (increases ohms) or multible in parallel (decreases ohms).
Hope this helps and good luck.7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi -
My dilemma is that the "rock" speaker works perfectly by the hot tub so that I can hear music while enjoying a nice soak. While the 60 is probably a better speaker, there's nowhere to mount it close to the hot tub.
I agree with you on not only running into problems running them either in series or parrallel, but also using totally different speakers for the left and right.
I may just have to give up the "rock".Things work out best for those who make the best of the way things work out.-John Wooden
