SRS update
neighbor
well second day with SRS,the imaging is like nothing that i have hearded,bass is low and tight mids very nice detail, but highs seem tinny. it will take some getting use to,thay are a total differant sound than the klipsch forte 1 that thay replaced.i have yet to really open them up,i fell that i am down on POWER,running them with nad c272 amp & c162 pre at 150w per into 8 ohoms,i really really really wont to open them up & let them breath DEEP, but am apprehensive i dont wont to damage them or the amp.if anyone could let me know what is working for them that would great. thank you,neighbor
Post edited by neighbor on
budget for an amp?
My vote to get your feet wet for the money is Adcom. GFA 585/555/5802. If you got the money go tubes.
Where are the pics?????
I'm off next weekend I'll drop off 450 watts for a demo. Your first upgrade should be tweeters, that'll get rid of the high problem.
Neighbor,
Congratulations on buying your SRS's. I have a pair of SRS's, which I run with Forte Model 3 Amp (200 WPC) and a Forte Model 40 Preamp. I'm very happy with the performance. I recently replaced the original tweeters with the RDO-194 replacements. In my opinion, definately made the highs smoother. I see you also have Klipsch speakers. I also have a pair of Cornwalls, which I also drive with another Forte amp/preamp. I also enjoy this set up alot. I'm a big fan of both Polk and Klipsch speakers. Enjoy your new SRSs -
Congrats on the SRS towers! Very fine speakers, they like lots of power. Use tubes only in your preamplifier. You need lot's of clean, high current power that solid state will give you. I'm partial to Parasound but there are other good amps out there. Some vintage Carver amps will also give you a good bang for the buck.Carl
Your first and most important upgrade to these should be getting the RDO-194 Tweeters from Polk. This will help eliminate the "tinny" sound you are experiencing. Most will state it is best to do all at once, but at a cost of 400.00 for all 8, I will only say they are worth it and leave it up to you as to how you decide to do it.
They are about the best speaker I have ever heard. Congrats!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I also did the 194 upgrade with 4 of them on my SRS2's and I can now listen to Celin Dion with-out the chalkboard cringes. They do need a few hours over a few weeks to burn in but when they do....OH man ..:DMost people just listen to music and watch movies. I EXPERIENCE them.
TOOLFORLIFEFAN wrote: »budget for an amp?
What do you think of the GFA-5800? -
See if you can get a pair of upgraded/updated Adcom 565 mono blocks. Strap the grounds and chasis together and you've got 300 watts of pure high current power.
Amp,,, this should do nicely
http://www.audiogon.com/cgi-bin/cls.pl?ampstube&1268676221&/Cary-audio-S120-Tube-power-ampJC approves....he told me so. (F-1 nut) -
george daniel wrote: »Amp,,, this should do nicely
That's purty! -
Congrats On Getting The SRS's, neighbor. You Must Be Extremely Proud, And Rightfully So Sir.
I'm With Carl 100% On What He Is Suggesting To You, Especially The Carver Amplifiers.
Take Care And Happy Listening, neighbor.
BILL(BB3)Sony 52in.XBR6
Sony 32in.XBR6
Anthem AVM50V
Anthem PRE-2L
Sonic Frontiers SFCD-1
Carver C-9
Carver C-19 PreAmp
Carver C-16 PreAmp
2-Carver Silver 7-T's
4-Carver TFM55's
2-Carver TFM35's
1-Carver TFM25
Carver 490T
Denon DCD1560
Sony BDP-S350
Sony PS3
Nintendo Wii
Panasonic DMK23DVR
Speakers :
PolkAudio SDA-SRS
PolkAudio SDA-SRS 1.2TL
PolkAudio SDA-CRS+(Compliments Of Mr. Jim Thomas"jtgranby")
PolkAudio RTA-15TL
PolkAudio M3
3-Velodyne F-1500's -
1) Rarely is damage done to a speaker with too much power - usually it is done with too little.
2) I am all for big amps and bi-amping see below.
3) Remember that it takes a 10 fold increase in power ie 100-1000 watts to double the perceived volume.
4) The picture of the tube amp in an earlier post which would do a wonderful job is rated at less power that what you are running now.
5) The big boys are not rated at 8 Ohms so you are most likely getting more power (than the 8 Ohm rating) out of the amp that you have.
6) Most of the time you are using very little power (10 watts or less to drive your speakers)
7) Lots of big amps are fun but not necessarilly needed for great sound.
8) Enjoy
Good Luck, Phil
SRS-SDA Front
2 cs400i Center
SRS-SDA Rear
Shure 12in sub
B&K ref 10 pre-pro upgr to ref 50
Techniques 1200 TT
Mac MR71 Tuna
Lexicon rt-20 uni player
HK citation pre for TT
2 PSE Studio Mono Blocks
4 PSE Studio Stereo Amps
1 Mac 2100 Amp for sub -
BILL(BB3)Phil Dawson wrote: »1) Rarely is damage done to a speaker with too much power - usually it is done with too little.
8) Enjoy
Good Luck, Phil
SRS-SDA Front
2 cs400i Center
SRS-SDA Rear
Shure 12in sub
Techniques 1200 TT
Mac MR71 Tuna
Geez, talk about "big boy" addicts. You guys are doing it right!;)
