Onix Rocket 5.0 speaker set (RS760's, RSC200, RS250's) - rosewood
Bump! Both are still available."I did not slap you. I high-fived your face."
what is the wattage rating of the elt?
Hmm.. not too sure how important 'wattage rating' is on speakers.. this is all they have spec-wise:
ELT525 Monitor
System Description: 2 Way
Woofer: 5.25 treated paper cone
Tweeter: 1 fabric dome with oversized surround
Enclosure Type: Vented, Rear Firing
Frequency Response (+/-3dB): 60Hz- 20KHz
Nominal Impedance: 8 Ohms
Sensitivity: 83dB @ 1w/1m
Crossover: 2200Hz, 2nd Order Acoustic
Raw Weight: 24 lbs pair / 10.8 kg pair
Shipping Weight: 26 lbs pair / 11.8 kg pair
Dimensions: 6.12 W x 11.25 H x 9.81 D / 155mm W x 287mm H x 250mm D
Mounting: 1/4-20 threaded insert built into the back and bottom. For wall mounting, we
recommend Peerless item# PM732
Video Shielded: Yes"I did not slap you. I high-fived your face." -
I like the sound of these. The ELT"S llook like clones
http://www.signalpathint.com/images/stories/Brochures/era_brochure_march_08.pdf -
Jeff, If you have not sold these by then, I would love to hear them at the GTG. I have always loved the look of that Bigfoot Center...
If I still have either (or both), and if I'm able to make it by, I'll bring it with."I did not slap you. I high-fived your face."
Either way, it would be great if you make it....
Even without the Onix's... j/k
BTW.. I tried to get a shot of the veneer on the one side, but was unable to get it to show anything in a pic. It's that light."I did not slap you. I high-fived your face."
Okay. This has to go.
$260 + shipping. I managed to get a couple shots of the one side I was talking about. High flash used to accentuate and show everything.
LAST reduction on the bigfoot to $250. Otherwise, it's going to Fleabay."I did not slap you. I high-fived your face."
great deal. someone on the west coast should really jump on this. jephdood, can you check the rate again to 11355 with fedex and usps?
Onkyo 805, RtiA5s, Csi5, Rti6s -
Yeah, not exactly cheap all the way over there (bigfoot only).
UPS - $68.88
USPS (Parcel Post) - $65.21
Oof.
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Oh, I forgot to mention also.. would consider trade/partial trade for HDMI receiver."I did not slap you. I high-fived your face."
whats the current price of the elt's for local pick up with cash.?
It's a beautiful day for a bump
Pricing reminder:
"Bigfoot" center - $250
Sanus stand - $75
"Bigfoot" AND Sanus stand together - $300
ELT Bookshelves - $150
(bottom-line numbers here)"I did not slap you. I high-fived your face." -
Sale pending on the ELT's. Bigfoot still hangin' around.
ELT's sold. 'SUPER' bump!
Everything *sold*"I did not slap you. I high-fived your face."
Thanks.
People were probably tired of seeing it, frankly. Heh."I did not slap you. I high-fived your face." -
Nah, they were some nice speakers...
Congrats on making the sales
