Bryston 4B ST power amp and the RTi 150's?
greyking
greyking Posts: 17
edited October 2003 in Speakers
Hello again. I am still shopping for a good pre amp/power amp for my RTi 150' s/ home theater set up. Just for now I pulled some stuff together out of the other rooms in my recording studio just to give them a whirl while I look for something more permanent. So here is the list of stuff and now I need some good advice on how to hook it all up and run it:
Bryston 4B ST power amp (250 watts per channel at 8 ohms)
Kenwood VR-7070 receiver
Polk Audio RTi150 front speakers
Polk Audio FXi30 surrounds
JBL SC305 center channel speaker
Cambridge soundworks model TEN A rear speakers
I plan on buying a sub soon and was wondering which SVS was the one to get. ???
I am also going to replace the JBL center with the Polk CSi40, and the Cambridge rears with the Polk RTi38's or another set of FXi30's.
Unless of course you guys have a better suggestion. Please let me know what you think.
I am kind of new to all this home theater stuff, but I learn fast. THANK YOU SO MUCH FOR ANY GOOD SUGGESTIONS!
Also here is a good review of the Bryston 4B-ST that I took out of my recording studio control room:
http://www.soundstage.com/revequip/bryston_4b_st.htm
Post edited by greyking on
    F1nut Posts: 51,674
    edited October 2003
    Bryston........hmmmmm good stuff. I think you'd be better off with the 9B-ST for HT.
  • greyking
    greyking Posts: 17
    edited October 2003
    I was able to pick up a set of RTi38's today, so on the list above replace the Cambridge TEN A's with the RTi38's. I guess I could use the FXi30's as rears and the RTi38's as surrounds. Or vice versa. What do you guys think? How should I run all this stuff?
