Turned off the loudness...
esowden
esowden Posts: 55
edited February 2010 in 2 Channel Audio
I was challenged by a sales reps at one of our two Home Audio stores to turn off the "loudness" setting on my Denon and bypass the tone controls for a week. (I had been complaining about highs being to bright and getting hard with higher volumes.)
So I did...
My first thought was - man, my system sounds like s**t. I realized I was listening to the XM receiver so I put a CD in - big difference but I still wasn't convinced.
I had an opportunity to just sit down and listen to a few CDs yesterday with no wife or kids around. I grabbed the 5 CDs I had been taking with me to test drive some new speakers and put them in the tray. Turned the stereo up to a decent listening volume and just listened to the music. (I've taken the time to audition some great speakers over the last few days in my quest for a new pair. This has more than pointed out the limitations of my current system.) I must say - the Monitors have never sounded better. They were no where near as fatiguing as I had experienced over the last 3 years.
I'm sure there are many of you who would say something to the effect of - "told ya!" I've read many comments about manufacturers needing to do away with tone and loudness controls. I don't know that I'd agree but - I'm no longer using mine. Thanks to Donnie at Barney Miller's Home Audio in Lexington, KY for the challenge and opening my ears.
Den
Parasound 2100
Parasound 2125
Denon DCM-390
LG BD390V
Martin Logan Preface(x2)
Denon AH-D2000
Bedroom
Adcom GTP-350
Parasound HCA-800II
Panasonic DVD-S54
Denon AH-2000
Polk S4(x4)
ಠ_ಠ
Post edited by esowden on
  • madmax
    madmax Posts: 12,434
    edited January 2010
    The fact is that with a decent set of speakers and a room that is reasonable you don't need tone control. Even if there are slight oddities you will become accustom to them.
    Vinyl, the final frontier...
    F1nut Posts: 51,699
    edited January 2010
    The better ones never had them to begin with and now you know why.
  • organ
    organ Posts: 4,969
    edited January 2010
    Yeah man. Don't use them. Unless you have some crappy recordings that need serious boost in the bass or treble. I bypass the controls on my pre.
    Tony M Posts: 11,585
    edited January 2010
    I agree about tone controls not being needed if all else it high grade.I found myself not using my equalizers as much and slowly without even noticing I left them out after moving a system around a bit or to the outside building.I don't even miss them AT ALL. I used to swear by them too.
    I still like a loudness button (if the amp has one) when listening at low levels and I even have the bass turned up just slightly on the SRS2 systems preamp.
    I thought about hooking an equalizer up to one of my newest systems just yesterday but it's not high on my priority list right now.;)..I would listen real close before the addition and then again and see what differences or distortion arises.
  • Mon40CSMM10
    Mon40CSMM10 Posts: 161
    edited January 2010
    Tone controls are locked out on the receiver I am using except for the Stereo, Front Stage Surround Focus/Wide, and Autosurround mode when it resolves to stereo only. This means I don't use the tone controls.
    Loudness is a different issue. When I added the subwoofer to the entire setup and set all the speakers to Small, I got plenty of bass drum out of the setup but I still wasn't getting string bass/bass guitar/bass synth sounds.
    I actually tried to avoid using Loudness. However--after trying a workarounds including setting front speakers to Large and using Plus mode for the subwoofer (way too overpowering bass for all types of music), setting speakers to Large and using separate high pass crossovers on the front speakers (okay, but not good enough for a variety of music beyond rock and dance music), turning up the subwoofer enough to hear the string bass/bass guitar/bass synth sounds (resulting in way too overpowering bass drum sounds)--the best bass for the setup I am using actually seems to occur with Loudness enabled and the subwoofer turned up barely above its minimum volume.
  • BlueFox
    BlueFox Posts: 15,251
    edited January 2010
    This can be a problem. Using an AVR to to play stereo music is full of possible errors due to all the setting possibilties. Assuming you have at the least moderate bookshelf speakers, then no sub, speakers at large, and direct mode. Take it from there by upgrading speakers and electronics to improve the sound.
  • thuffman03
    thuffman03 Posts: 1,325
    edited January 2010
    I was a fan of always keeping the controls at dead center till I was at Carverfest 2009. I had the chance to sit and listen with Bob Carver and he is a tweaker to the 10th degree.
    And from what I took from my time spent listening with Bob was that the more control you have the better you can make the sound.
    He really was able to make the adjustments needed and I could hear a difference. Now with me going home and trying to do the same, I have to say I have a hard time to do what he did but I have changed my mind and started to tweek when I can to little avail but it has made me rethink on how I listen to music. IMO, sound can always sound better but I do not have the ability yet to do so.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • BlueFox
    edited January 2010
    thuffman03 wrote: »
    True. The point is you need to know what you are doing, and you need to know what 'good' sounds like. Sort of like a musician tuning their instrument. Additionally, in order to really make a difference one needs more than a balance, treble, and bass control. You need to control every frequency.
    The problem is 99.99999% of the population does not know what they are doing, and controls just give them the opportunity to screw things up. Of course, it's their equipment and they can do what they want.
  • organ
    organ Posts: 4,969
    edited January 2010
    You also degrade the signal as you add more controls. That's why minimalist SET systems sound so good. It's as simple as it gets. I'd rather put the money on room treatments to fix anomalies.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    organ wrote: »
    Bingo!
  • comfortablycurt
    comfortablycurt Posts: 6,745
    The loudness control isn't really something that's meant to be used at all times. I was guilty of leaving it on all the time with my first stereo's though.
    It's really just meant for boosting mid-frequencies at lower volumes, to give the illusion of having a fuller sound. It can be useful at times, but for the most part you're better off without it IMO.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    I never use any loudness controls for 'critical' listening but if I'm playing the FM at low volumes at night..yeah I boost the sound--but then it's really only 'background' music.
    2 channel has always sounded best with no treble or bass adjustments...just Pure Direct on the Denon/Adcom pre/amp!
    cnh
  • steveinaz
    steveinaz Posts: 19,545
    Years ago I was a treble junkie. It was like sugar for me. Now I look back I wonder how I have any hearing left. What I did when making the "transition" to 0dB, I spent the first week with the treble turned all the way down to -6db from flat. It got me off the "stuff" and I have been on the wagon ever since.
    My name is Steve, and I'm a recovering trebleholic.
