Adcom CD players
acmf74
acmf74 Posts: 937
edited January 2010 in Electronics
Anyone have experience with them? How is the sound/quality?
Thanks,
ACF
Post edited by acmf74 on
  • fbm211
    fbm211 Posts: 1,488
    edited January 2010
    The 750 might be ok.I had a 575 and thought it was ok...till I got a theta data basic.In comparison the adcom was way too forward in the mids.Now I think they suck.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
    heiney9 Posts: 25,432
    edited January 2010
    The 750 is actually outstanding, plus it can be used as dac as well because it has a digital in/out. It uses the exact same analog/digital components as the GDA 700 dac. The only gripe is the display is very difficult to read from across the room.
    The 575 was a nice player for the day, but they are approaching an age where they just plain wear out and aren't really worth the cost to fix. If you buy one cheap enough, just run it till it dies.
  • acmf74
    acmf74 Posts: 937
    edited January 2010
    Thanks for the replies but what is a DAC?
    Toolfan66 Posts: 18,048
    edited January 2010
    Digital to Analog Converter
    edited January 2010
    By the way I like my Adcom GCD-750
  • danz1906
    danz1906 Posts: 5,144
    edited January 2010
    The GCD-750 is a great player with a Digital input.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
