Thinking interconnects
sageleo
I need to get some new interconnects when I setup my new system in a few days. My local stores only carry AR and monster, and I'm not wanting either of those really. Can someone help guide me in the right direction for some good quality cables. As far as budget is concerned the cheaper the better, but more concerned with quality.
Thanks,
Dirk
Thanks,
Dirk
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
Signal cable
Signal Cable x 2. Call Frank at SC, 917-957-8508 and tell him you are a member of this forum and you will get a discount.
That is one of the three I have be thinking about. Right now I'm on the fence between Signal cables, Audio Quest, and Kimber Kables. Is Signal better then the other two or just a better price?T.V.- Sony KDL50W800B
Vizio Sound bar- S4221W -
Audiogon...SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
i replaced some cheap ones i had with audioquest (and they were one of the lower end ones) and it was a noticeable improvement. Theres still better value cables out there but i just wanted to pick em up at a local store and be done with it.HT basement room:
TV- 42in Panasonic S1 Plasma
A/V Receiver- Onkyo NR807
Blu-Ray- 80GB Sony PS3
Power Supply- Monster HTS-1600
5 Disc Sony CD/DVD Changer
Time Warner HD Cable Box
Speakers:
Front- Polk RTi A3
Center- Polk CSi3
Side Surround- Polk RTi4
Back Surround- Polk RM6750
Sub- Outlaw Audio LFM-1 EX
Bedroom:
32in Visio LCD, Sony STR-DE685 AVR, MTX Monitor 12, Sony 5 disc DVD changer
