Thinking interconnects
sageleo
sageleo Posts: 170
I need to get some new interconnects when I setup my new system in a few days. My local stores only carry AR and monster, and I'm not wanting either of those really. Can someone help guide me in the right direction for some good quality cables. As far as budget is concerned the cheaper the better, but more concerned with quality.
Thanks,
Dirk
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
  • Willow
    Willow Posts: 11,246
    edited January 2010
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    Signal Cable x 2. Call Frank at SC, 917-957-8508 and tell him you are a member of this forum and you will get a discount.
  • sageleo
    sageleo Posts: 170
    edited January 2010
    That is one of the three I have be thinking about. Right now I'm on the fence between Signal cables, Audio Quest, and Kimber Kables. Is Signal better then the other two or just a better price?
  • fbm211
    fbm211 Posts: 1,488
    edited January 2010
    Audiogon...
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • keeneyrm01
    keeneyrm01 Posts: 80
    edited January 2010
    i replaced some cheap ones i had with audioquest (and they were one of the lower end ones) and it was a noticeable improvement. Theres still better value cables out there but i just wanted to pick em up at a local store and be done with it.
    HT basement room:
    TV- 42in Panasonic S1 Plasma
    A/V Receiver- Onkyo NR807
    Blu-Ray- 80GB Sony PS3
    Power Supply- Monster HTS-1600
    5 Disc Sony CD/DVD Changer
    Time Warner HD Cable Box
    Speakers:
    Front- Polk RTi A3
    Center- Polk CSi3
    Side Surround- Polk RTi4
    Back Surround- Polk RM6750
    Sub- Outlaw Audio LFM-1 EX
    Bedroom:
    32in Visio LCD, Sony STR-DE685 AVR, MTX Monitor 12, Sony 5 disc DVD changer
